Stainless fuel lines - Defender Source
Old December 12th, 2012, 04:35 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Update on my experience with Classic Tube.
I purchased a set of fuel lines in August, (that was an issue in it's self) and finally got them on the project this week. After priming the engine for oil pressure and priming the fuel system, we started the engine.
Maybe 2 minutes run time and happened to look at the back of the car to see fuel running out in great volume. The rubber portion of the return line had seperated from the fitting at the pump, filling the well where the pump sits and then started running out of the fuel tank cradle.
Of course on the return side, the engine continues to run so we weren't immediately aware that there was an issue.
The hose looks like it is severed right where the inner portion is screwed into the outer portion. The outer fitting is a smaller OD than the same fitting on the pressure hose, but both rubber hoses are stamped 5/16".
Oh, and there was a big piece of swarf in the fuel side of the fitting.
I called them first thing this morning, sent pictures, and hadn't heard back by late afternoon.
I'll post an update, hopefully very soon.
ID:	62667   Click image for larger version
Email is
Same place, new dogs.
Old December 12th, 2012, 04:48 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
One of these things is not like the other......
Old December 13th, 2012, 09:08 AM
Roverlab
Trevor Griffiths
I called CT after I posted yesterday afternoon, was assured they were looking into it and we left it at that. Got a call just now from Tim Slattery at CT to confirm my shipping address. They are stepping up to get a replacement made up and out the door today, so can't complain about that.
Now, let's see what we get!
Email is
Old December 13th, 2012, 11:01 AM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
So is it set then that there are absolutely no AN fittings that match up?
fuel
Stainless Fuel lines MAX711 Defender Technical Discussions 2 July 7th, 2011 03:05 PM
Stainless steel extended brake lines Chris Cox For Sale - Parts 1 February 8th, 2005 01:34 PM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
