Stainless Fuel lines - Defender Source
Old July 7th, 2011, 11:07 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
So I ordered some stainless fuel lines for a '94 D-90 from Classic Tube in Buffalo, NY.
When they arrived I only had the supply line(s), no return. I called and they only have a return line for a '97 D-90. He thought it might be a misprint in the catalogue.
Does anyone know if there was a difference in the return lines between a '94 and a '97?
Thanks for any help.
P.S. They're very well made by the way and come with all the rubber hoses and fittings. $199 for the 3 part supply line, not sure how much the return line is yet.
Old July 7th, 2011, 01:37 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The return line is the same.
Have them make them with the SS braided flex hose. We found the rubber hose they use dry rots quickly and kind negates the longevity of a SS line.
Email:
Old July 7th, 2011, 03:05 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Will do. Thanks for the quick reply.
fuel
stainless steel fuel, brake, oil lines ditskovich Defender Technical Discussions 4 April 6th, 2009 07:01 PM
Stainless steel extended brake lines Chris Cox For Sale - Parts 1 February 8th, 2005 01:34 PM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
