stainless bolts for hinges - Defender Source
Old December 30th, 2007, 07:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have been slowly replacing the bolts on my truck with stainless. I just pulled my doors apart to dynamat them so while I was there I replaced the hinge bolts on the doors sides of the hinges. My question is when I replace the hinge bolts on the frame side how do I get to the backside of the framing to replace the nuts?
thanks
Old December 30th, 2007, 08:37 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
They are cage nuts that clip on the bulkhead. If that is the part you are speaking of. You will understand once you take the door off. Tie a string to them so when you drop one you can retrieve it. Otherwise, you will be fishing a magnet or something down there to get it out.
They look similar to this:
http://www.diecoinc.com/enlarge_phot...photoid=u-nuts
Old December 30th, 2007, 08:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
How do you suggest I do this. Close door, unscrew top hinge from bulkhead and swing it out. Will I then see what you mean?
Old December 30th, 2007, 09:29 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Yes. Just make sure you do them one at a time so you minimize the risk of putting your door out of alignment.
Make sure you tie a string well to those cage nuts! I lost mine way down in the bulkhead... it's still down there
Old December 30th, 2007, 11:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
how do you get the string off once tight?
Old December 31st, 2007, 08:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
got it done. made perfect sense once apart.
thanks
Old February 16th, 2010, 05:15 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Hypothetically speaking if you were to drop something down the bulkhead how would you remove it?
Old February 16th, 2010, 05:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
I lost a couple down in there. Whats one more rattle
Old February 16th, 2010, 05:24 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I dropped one and pulled it out the hole that is used for the speaker wire in the bulkhead. I used a magnet. I also tack weld the nut to it's holder as I had a couple nuts come free.
Old February 17th, 2010, 12:06 PM
I lost one and had to use an old bolt until I could get a replacement ... the stainless bolts had a different thread pitch.
Old February 17th, 2010, 02:28 PM
Wait for it to rust out ...
Old February 17th, 2010, 03:42 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Wait, they don't just drop right out the bottom through the large rust opening?
Old February 17th, 2010, 04:37 PM
Not on my truck!
bolts
ST doors, Door Tops and Stainless Bolts tomaco1 For Sale - Parts 7 June 16th, 2009 09:25 PM
Blackened, Stainless Roll Cage Bolts! JimC Defender Technical Discussions 40 January 9th, 2008 02:08 PM
Stainless door hinge bolts and other rust rustydefender Defender Technical Discussions 28 September 15th, 2007 09:59 AM
stainless wing bolts rgrrvr Defender Technical Discussions 1 June 28th, 2007 07:15 PM
Stainless window bolts Peter Defender Technical Discussions 1 July 6th, 2004 10:44 AM
