stainless bolt strength questions.. - Defender Source
Old June 14th, 2014, 09:42 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Well, the headliner shop called and said the headliner is done. I'll go pick up the 90 in a few days, re install rear trim, seats, etc. I was going to just buy stainless bolts at the local hardware store, ACE, which does have an incredible assortment, but started thinking about the "strength" of the actual bolts that hold down the rear seat "anchors".
Does it matter? Would the force necessary in a wreck, if someone were in that seat, to rip the head off of the bolt be something less than what it would take to just pull the whole damn thing through the aluminum? I know that the seat belts are anchored in other places so does it just make my question idiotic? I keep reading about "Grade 8" etc and was just wondering if I'm making a mistake by using stainless for its obvious qualities.
FWP, I know
KCD
Old June 14th, 2014, 10:12 AM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
There's a thread here from few years ago about using stainless on the roll cages. If you do a little more digging here, you might find it.
Found it. There might be some valuable information here.
http://www.defendersource.com/forum/...ight=stainless
Old June 14th, 2014, 10:27 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Just a thought here, if the seat pulls loose but the belt holds you will have that much more force above your body weight pushing you against the seat belt in the initial impact. Then if the seat is loose you are much more likely to sustain injury if the vehicle continues to move such as in a rollover.
Old June 14th, 2014, 10:42 AM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
You can get grade 8 stainless...but it can get pricey.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old June 14th, 2014, 11:20 AM
jac04's Avatar
jac04
Jeff
Currently Roverless
"Grade 8" technically refers to SAE J429 specification, which are not stainless. But, yes, you can get high strength stainless fasteners and, yes, they are relatively expensive.
Old June 14th, 2014, 11:23 AM
there are limitless combinations of stainless steel and heat treatments. afaik sae grade 8 is for cad plated non stainless steels only.
ace hardware sells 18/8 fasteners only which have very low tensile and yield strength.
rough stainless equivalent to grade 8 is 17-7 ph condition a and condition c completely exceeds grade 8.
in other words, stainless steels can have much higher stengths than grade 8. you will not find these fasteners at ace. try fastenal, mcmaster, or others online.
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ what he said. ^^
I would not substitute what the engineers required for fasteners in something so critical.
Rent my
Old June 14th, 2014, 11:52 AM
kevincdoyle
Kevin C. Doyle
Thanks lynchee!! I had searched but think I was using too many terms. Thanks again!!
Old June 14th, 2014, 01:15 PM
another point to make: rover aluminum is much weaker than Ace Hardware grade stainless.
The bolt will tear out of the aluminum before the bolt fails.
Old June 14th, 2014, 01:26 PM
The mass of the seats themselves at a few tens of pounds is relatively minor. In an impact I doubt that they would move much at all compared to a body, which tends to be 150-250 plus pounds. Way more mass. The seatbelt anchors are what you should be concerned with. Usually they are mounted with the bolts in shear loading, which is quite high even for relatively small fasteners. So your stainless fasteners are plenty strong to hold the seats, but stick with the factory fasteners for the belts.
Old June 14th, 2014, 04:58 PM
kevincdoyle
Kevin C. Doyle
This is my favorite answer!
Thanks so much!
KCD
Bling Master J's Stainless Steel Bolt Kits - Group Buy JimC Misc. Chit-Chat 67 April 11th, 2012 12:47 AM
Higher strength U-joints? hillstrubl Misc. Chit-Chat 10 May 31st, 2011 02:30 PM
Stainless bolt kits rayfi Wanted 22 October 29th, 2008 08:26 PM
Stainless Bolt Kits for 90s and 110s Stmpede For Sale - Parts 33 March 17th, 2008 10:54 PM
Stainless Bolt Kits ronward Defender Technical Discussions 2 January 26th, 2004 12:57 PM
