ST windows slide - Defender Source
Old May 10th, 2004, 09:47 AM
Cyborg
Larry Walton
'97 D-90 ST #2066 UK 4X4
ST windows slide
On my ST the windows on one side do not "pinch" properly to keep them from sliding with the handle I turn to hold them. I am assuming there is a worn part inside the door top frame that is not properly applying pressure to the windows to keep them pinched shut. Has anyone had this happen? What is the best way to gain access to this area? Looks like there is one silver screw that I could take out and possibly remove the unit but I am afraid I may drop a nut loose inside the door top frame or something. I have not found any info on this anywhere.
Any advice would be appreciated.
Larry
Visit the Land Rover Beer Bar,"The Best Beer Bar X Far!"
Old May 10th, 2004, 10:09 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The exact same thing is happening to mine. Trying to figure out how to fix it right now. I hope somebody knows!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 10th, 2004, 12:47 PM
I drilled out the 4 rivets and put a round washer between the two nylon "fingers". I then riveted it back together and it works fine for the last 6 months. Good luck...
Old May 10th, 2004, 12:50 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I just called George at RDS and he said that you can buy all the stuff separately to "rebuild" the window so it works properly. I am going to go through my parts manual and get all the right pieces that I need and fix it that way. New door tops are going for $370 a piece!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
slide, window, windows
Roll-up windows for a soft-top? jam90 Defender Technical Discussions 1 January 11th, 2006 11:33 AM
Rattling ST Windows? mlw911 Defender Technical Discussions 0 October 26th, 2004 06:55 PM
More Softtop Help - 97' Windows jbird Defender Technical Discussions 2 April 27th, 2004 11:39 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
Door Windows on '97 D90 Rob Defender Technical Discussions 4 November 3rd, 2003 04:11 PM
» Defender Registry
Grover
Cobramax
Bess
Yorkie
Add your Defender
