ST window storage solutions for the trail - Defender Source
Old September 11th, 2011, 03:08 PM
seriousactualist
Paul Martin
1995 D90 ST
Does anyone have or know of any good ST window storage solutions that work well on the trail? The use case I'm thinking about is driving to the trail with the windows in and then removing and storing (as desired). I'd typically not have quick/easy access to the floor of the tub, and likely wouldn't want to pack them under a few hundred pounds of other gear -- or lying unsecured on top of that gear.
Something like the Clover Patch Window Roll seems like a cool idea. (I'll have to see if the Bestop windows will fit.)
Other thoughts or solutions (other than just buying a Badger II )?
-- Paul
Old September 11th, 2011, 03:19 PM
Besttop made a bag to hold all 3 rear windows. There's at least 1 actively for sale right now.
http://www.defendersource.com/forum/...ad.php?t=33014
They work just fine for your needs.
Old September 11th, 2011, 03:33 PM
seriousactualist
Paul Martin
1995 D90 ST
I'd asked Rob about this and he thought that bag had to lay flat. That initially seems a little problematic to me, but maybe I'm over-thinking things.
Thanks!
Old September 11th, 2011, 03:37 PM
The bag is not the issue, it's the windows themselves that limit your abilities to roll them up.
Old September 11th, 2011, 03:44 PM
seriousactualist
Paul Martin
1995 D90 ST
They're certainly pretty flexible at (ahem) higher temperatures. Forgive the stupid question, but is it a bad idea to roll them?
Old September 11th, 2011, 04:57 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Rolling doesn't hurt them. Just roll them when it's warm and you'll be fine. I have a Badger top with blanked sides that roll up and lash in place. The rear window, I just roll it in a warm garage and leave it up all summer.
Rolling the top is a fall/spring ritual for me.
Old September 11th, 2011, 05:19 PM
seriousactualist
Paul Martin
1995 D90 ST
Thanks Chris and Joshua!
The only issue I see with rolling the side or rear windows is in cold weather (when cracking might occur).
-- pm
Old September 12th, 2011, 10:52 AM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
The other issue with rolling the windows is that it can cause scratches when the plastic rubs together.
Old September 12th, 2011, 12:57 PM
Put some cloth between each window as you stack them
Originally Posted by pendy
I'm here for the D's
Old September 12th, 2011, 02:04 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
You can also get a flat case to store them from an art supply house ( presentation case)http://www.dickblick.com/categories/portfolios/
window
ST Window Top Rehab kevkon Smaller Projects 3 August 13th, 2011 09:45 AM
Rear window for 94 st Lindy Wanted 0 February 4th, 2009 06:57 PM
ST Window Storage Bag mpodgorski For Sale - Parts 3 June 3rd, 2004 01:07 PM
st driver&passenger window bases fill with water Marc Weinstein Defender Technical Discussions 6 April 15th, 2004 06:52 PM
ST rear window clip! TwisteD90 Wanted 2 November 12th, 2003 11:53 AM
