ST Window and tailgate? - Defender Source
Old October 23rd, 2004, 11:07 AM
mlw911
Michael Walter
1995 D90 ST
Redoing my windows and wanted to know if the seal at the bottom that rests on top of the st door should be glued to the bottom of the window or float?
On my tailgate there are 2 screws though the brackets that allow the tailgate to hinge and swing. The bottom has some sort of lock washer holding it on it but the top one just has double nuts holding it on and keeps loosening up. What sould this setup be?
Old October 24th, 2004, 07:34 AM
mlw911
Michael Walter
1995 D90 ST
b..p
Old October 24th, 2004, 12:08 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
The seal should be attached to the window.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old October 25th, 2004, 08:05 AM
mlw911
Michael Walter
1995 D90 ST
Thanks Burke. Maybe someone could post a pic of the screw and nut combination that attachs the tailgate to the body.
Thanks.
Michael
Old October 25th, 2004, 08:53 AM
Wait, I'm not quite tracking - is this two issues? Are you asking these questions:
1) does the weather stripping just slide into the bar at the base of the rear window (if so, thats been answered)
2) What hardware combination should be used on the tailgate hinges? (if that is the question, then both are the same, and you can refer to the attached pic)
If it is something else, please mention it, I'll do my best to help.
Name:	Fresh Hinge Parts.jpg
ID:	1709   Click image for larger version
Name:	Fresh Hinges.jpg
Old October 25th, 2004, 06:27 PM
mlw911
Michael Walter
1995 D90 ST
Thanks Jim, that's what I needed.
tailgate, window
soft top part - tailgate rail Hazard Wanted 7 July 9th, 2013 08:59 AM
Fiberglass top tailgate window gas struts part# AmityD90 Defender Technical Discussions 5 October 27th, 2010 10:47 PM
WTB: Plastic Brackets for Bestop Tailgate Bar proulx70 Wanted 0 October 7th, 2008 04:06 PM
Fitting an handle to a tailgate...? Cube II Defender Technical Discussions 7 February 22nd, 2007 10:02 AM
94st: Hardtop To Tailgate Seal? 4WD-90 Defender Technical Discussions 11 November 8th, 2004 06:38 AM
