ST tire carrier dis-assembly - Defender Source
Old November 4th, 2009, 09:41 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
Just got my bolt upgrade kit from AB, its high time I got rid of those squeaks and rattles. Just a little confused as how the tire carrier goes together. Perhaps I'm over thinking it.I checked RAVE and didn't see anything. I searched here but didnt find exactly what I am looking for. Can somebody show my the light??
This is where I'm supposed to write something witty and funny; or something.
Old November 5th, 2009, 12:32 AM
bjf's Avatar
bjf
barry f
94 ST #395
It is really simple. I t all just bolts together. The bushings are a bitch to remove though
Old November 8th, 2009, 11:45 AM
JBOD77
Jonathan
OK, so I'm getting things apart. Taking my time as there is a newborn in my house and things are still a little crazy. Once the bolts are out and you move on the the bushings, how the hell do you get them out? Ive tried get a screwdriver in between them to bang it out but its not budging. I've read about using a socket about the same size but unless on of the 2 is out, I fail to see how that's possible. Any tips hints advice voodoo magic or anything else would be appreciated.
Old November 8th, 2009, 12:29 PM
Slide hammer.
Old November 8th, 2009, 01:07 PM
JBOD77
Jonathan
ok so maybe i'm not understanding but how would i get the slide hammer to purchase the bushings??
Old November 8th, 2009, 01:51 PM
I used a big screwdriver and a hammer to get mine out. Doesn't mess em up too bad if you are cheap and want to re-use them
Old November 8th, 2009, 01:52 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I used an internal bearing puller, it is like a slide hammer but is designed to expand jaws on the inside of a bearing and then you use the slide hammer part to pull the bushing or bearing out.
Many auto parts store will lend you one for free. Once you have one side out you can then use a 15mm socket to push the other side out
If you look at my thread in the small projects section the mcmaster-carr part number for the bushings is listed in there if you need to replace them
Old November 8th, 2009, 07:09 PM
Jonathan, the way they usually work is they have hooks on the end on a threaded rod that expand the hooks as you tighten. So you insert the hooked ends into the bushing, tighten a nut which pushes the hooks out.
assembly, carrier, tire, tire carrier
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
stock ST spare tire carrier w/light bar WhiteD90 Wanted 3 July 1st, 2004 10:57 PM
Modify ST Tire carrier for SW use? dnewman9 Defender Technical Discussions 1 June 27th, 2004 06:06 PM
