st driver&passenger window bases fill with water - Defender Source
Old April 13th, 2004, 10:44 PM
Marc Weinstein
Marc Weinstein
defender 90 '94
during heavy rain window base frame fills with water and either pours foward going downhill or pour to rear of window channel overflowing on door locks etc. shouldn't windows have weep holes into doorframe and then out bottom of door. any suggestions? Thanks.
Old April 13th, 2004, 10:47 PM
yellowrover's Avatar
yellowrover
Mike Holland
'97 AA Yellow D-90 ST
Marc,
That happened to me too, the weep holes filled up with junk and just blocked the water when it rained, whenever i turned into my driveway, which is up hill, the water poured into the passenger seat. I just took a hose and squirted water in through the weep holes which are on the bottom of the window, where the top of the door meets the bottom of the window frame, that shot the junk back out through the top and cleared it up
Old April 13th, 2004, 10:49 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I drilled holes in the bottom of the door frames.
Old April 13th, 2004, 11:27 PM
Marc Weinstein
Marc Weinstein
defender 90 '94
water is not getting into the door frame fast enough or at all-it's staying in the bottom of the window frame(in the space of window lock-from one side to the other) water then spills out of bottom of glass frame area when truck is not level!!
Old April 14th, 2004, 11:27 AM
yellowrover
Mike Holland
Thats what happened to me, the weep holes for the window are on the outside of the door where the window frame meets the door. They are lil slits near the rear and front ofthe frame.
Old April 14th, 2004, 03:05 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
TIME TO GET GOLD FISH!!!
Got'a love the D-90...
Weldon
Old April 15th, 2004, 06:52 PM
COSteve
Steven Reed
93 Defender 110 - #107
The window seals, inner and outer, should keep the water out.....right?
I have new ones to install, has anyone done it ? Are the riveted in?
COSteve
water, window
ST Window Stud mikeybob2@msn.com Wanted 0 April 25th, 2009 07:31 AM
Rear window for 94 st Lindy Wanted 0 February 4th, 2009 06:57 PM
ST Window Storage Bag mpodgorski For Sale - Parts 3 June 3rd, 2004 01:07 PM
ST rear window clip! TwisteD90 Wanted 2 November 12th, 2003 11:53 AM
