ST Door Top Plastic Tube - Defender Source
Old February 18th, 2010, 04:09 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I have my ST door tops off and was wondering what purpose the plastic space tube serves. I am missing one in each door.
I think my seals were installed incorrectly. I've read about this somewhere but I can't find the thread, which way is "up"?
Old February 18th, 2010, 04:16 PM
Krna
Andy Krna
1997 D-90 ST AA Yellow
Plastic tubes are meant to keep it from rattling. They tend to fall out, I use a set of clear plastic tubing that I picked up at home depot and fits tightly on my badger door tops. I have not used the real door tops since getting the badgers a few years ago (well worth the investment), but i think for the seals, the flat side lays against the door and the "flaps" go up the door top sides, if I recall correctly.
Old February 18th, 2010, 05:06 PM
Which ones are you missing the black or the gray?
Old February 18th, 2010, 05:17 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Gray? Mine are black.
Old February 18th, 2010, 05:40 PM
On each door top, I have one gray and one black. I think I may have an extra set, but I am not sure what they cost. Or, you could try the rubber tube from Home Depot or Lowes.
Old February 18th, 2010, 07:34 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I had all gray tubes, but after a wreck the body shop left the plastic tubes off the passenger side. I have been running the last few years with plastic tubes on the drivers side and no tubes on the passenger side and no adverse effects. The home depot idea is a good one though. I will have to remember that next Sept when I put the door tops on again.
Old February 18th, 2010, 07:41 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
What tubes are we talking about?? Do these attach to the door or the top??
I feel like I am missing something...
Old February 18th, 2010, 08:21 PM
Mike, yes the tubes we are talking about cover the stud on the door tops, before it is inserted in the door.
You are going to Uwharrie in April, right?
Old February 19th, 2010, 09:44 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
hmm... me thinks i am missing those tubes. I can't recall ever seeing anything like that. oh well...
Scott, that's the plan! It's definitely on the calendar. I assume you're going to be there?
door
little plastic thin piece that is glued down to cover the light near the heat switch d90guyinla Wanted 10 February 5th, 2013 05:01 PM
WTB: plastic tube that goes from fender grate to heater LHD tomaco1 Wanted 13 September 5th, 2008 08:53 PM
Soft top plastic windows paulb Defender Technical Discussions 8 March 22nd, 2005 08:58 PM
Need plastic rivets to hold side step Campbell Wanted 2 March 21st, 2005 04:41 PM
