ss bolt kit installation question - Defender Source
Old December 4th, 2005, 12:40 AM
geneseemtn
shane
curently without rover
When installing the ss bolt kit on my '97 SW, I ran into an issue on the side door hinge bolts.
The two FRONT bolts on the BODY side of the hinge came out just fine, but the two REAR bolts on the DOOR side of the hinge just keep turning, like there's a nut on the back side that just spins with the bolt so the bolt won't come out. Does the interior trim of the door need to be removed to get to the nut on the back side? If so, please offer some suggestions to get the interior door trim off.
Thanks in advance.
Old December 4th, 2005, 01:04 AM
Yes the trim needs to come off because there is a nut there.
Old December 4th, 2005, 12:28 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
If you want, you can take half of the door trim off to get a wrench on the nut. I had problem getting the frame side bolts out, so I left the those off and replace the door ones.
installation, kit
Bolt Question Buckon37s Defender Technical Discussions 5 January 30th, 2007 08:28 PM
rear bolt kit for 97 ST cafemosaic Wanted 0 January 25th, 2006 10:47 PM
Replacement Bolt Question ronward Defender Technical Discussions 4 January 12th, 2006 09:30 AM
Mud UK bolt kit from EE wicks Misc. Chit-Chat 0 November 28th, 2005 11:36 PM
New non-corrosive alloy door hinges and bolt kit c2sox Misc. Chit-Chat 24 December 8th, 2003 03:16 PM
