squeeking noise - Defender Source
Old April 6th, 2005, 09:59 PM
jracenstein
Jeffrey Racenstein
squeeking noise
My truck is making a high pitched squeek when i accelerate but stops when the truck is going over 50 mph. Anyone have any suggestion as to what may be making the noise?
Old April 6th, 2005, 11:28 PM
Wheel bearing? U-joint? break pads? Need a little more info.
Old April 7th, 2005, 02:53 PM
jracenstein
Jeffrey Racenstein
I'm not sure but its not the brakes
Old April 7th, 2005, 03:21 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Alt bearing, tensioner pulley (don't know if the D90s have this, I guess the 4.0 w/serp belt has it).
John C.
Old April 7th, 2005, 03:56 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
If the squeek changes with speed it would be U joint/esp if it is under the truck. If the squeek changes with the application of the brakes then it might be the brakes. If the noise changes with engine rpm then its probly under the hood. If you leave cheese on the front seat, in a mouse trap & it catches the mouse, > your squeek is gone after that> it was a mouse! Good luck
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
now... a loud squealing noise... norros Defender Technical Discussions 2 May 3rd, 2005 09:58 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
