Squeals Like A Stuck Pig - Defender Source
Old May 26th, 2016, 11:23 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
1994 Defender 90 - insert key into ignition switch; turn key to start position; starter turns; engine starts; release key to run position. At that moment a "SQUEAL" is heard from the engine compartment. Last less than a second. No other obvious problems. Anyone have an idea where the pig is hiding?
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old May 26th, 2016, 11:37 AM
Naplm00
Matthew
Serpentine belt and or tensioner need replacement most likely
Old May 26th, 2016, 11:46 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I think all 94 D90's are v-belt so it might take more investigation,,,
Rent my
Old May 26th, 2016, 11:47 AM
Starter hanging up?
Old May 26th, 2016, 11:51 AM
Sounds like a weak or broken bendix spring, if its just for a second when you release the key from the start position
Old May 26th, 2016, 12:01 PM
Naplm00
Matthew
Lol good point, still think it's some. Kinda belt
Old May 26th, 2016, 12:31 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
If you're by yourself, just spray the belts with a little WD-40 prior to your startup.
That will at least tell you if it is BELT related if it eliminates the squeal momentarily....
Rent my
Old May 26th, 2016, 01:28 PM
Grover's Avatar
Grover
Check the tension and condition of all the belts first.
Old May 26th, 2016, 02:21 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
Just had all the belts replaced last month.
The Wizard
Old May 26th, 2016, 02:42 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
a-ha.....
Rent my
Old May 26th, 2016, 02:51 PM
damn. I thought this thread was about Briggs. my bad
Mark Kellgren
KM4BOR
Old May 26th, 2016, 02:57 PM
starter bendix failing to retract after engagement of the flywheel.
Lipstick on a Pig - Rage Rover Grill CDeWan Misc. Chit-Chat 12 August 19th, 2012 03:37 AM
am I a pig? Campbell Misc. Chit-Chat 28 July 26th, 2012 04:45 PM
Need a guinea pig chrisvonc Misc. Chit-Chat 12 January 8th, 2010 07:50 PM
I'm happier than a pig in S***T Ren Ching Misc. Chit-Chat 11 September 17th, 2009 10:56 AM
Center Diffs (Pig in a Bucket) Hammertime Defender Technical Discussions 3 March 17th, 2008 12:31 AM
