Squeal at 2k RPM. - Defender Source
Old November 15th, 2009, 03:19 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Squeal at 2k RPM.
aI get a whine from the engine at 2k rpm when it is under load. Almost sounds like a fan belt squeal.
I just replaced the water pump 500 miles ago, it was shot, it would make the noise before the pump change.
I can't recreate the noise in my garage. Any suggestions?
Thank you!
-Josh
Old November 15th, 2009, 06:56 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Josh I remove the drive belt and replace it with a rubber belt that i can tie off to a miss out a component to test, this allows me to test individual components by eliminating them from the drive belt.
It may be the alternator bearings, remove the drive belt and turn the pulley by hand to feel for play or roughness.
hope this helps
Gren
Old November 17th, 2009, 04:31 PM
Quimbola's Avatar
Quimbola
Josh
Thank you. I will try it this weekend.
What are you using for your rubber belt?
Old November 17th, 2009, 04:47 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Josh a piece of the ribbed rubber mat from the floor of my tub cut into a strip with holes punched into it so i can adjust the length.
regards
gren
Old November 17th, 2009, 06:09 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
You can also isolate a squeaky belt with soap and water. Spray it on the suspect belt, and it should go quiet for a short time until the water evaporates. Just don't use any of the "belt quiet" sprays on there. It really does a number on the belt, doesn't last long, and you need to clean it off all the pulleys when you finally do change the belt.
Could also be the alternator bearing, or the tensioner bearing.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 18th, 2009, 11:10 AM
Quimbola's Avatar
Quimbola
Josh
I am hoping it is something easy.
AC compressor clutch squeal artm Defender Technical Discussions 9 June 14th, 2010 04:34 PM
RPM Fluctuation Billakris Defender Technical Discussions 5 March 28th, 2005 10:52 PM
Engine sputtering chugging between 2650-3200 rpm Heath Defender Technical Discussions 14 February 8th, 2005 08:36 AM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
D-90 occasional missfire around 2000-2500 rpm Toddco Defender Technical Discussions 15 October 22nd, 2003 05:40 PM
