Squeaky steering wheel Def 90 - Defender Source
Old June 6th, 2015, 10:37 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
My steering wheel has been squeaking loud when turning the wheel in one direction (not really the other) and it drives me nuts. It is right at where the steering wheel meets the steering column I believe. Any ideas? Should I spray some silicon in between there or take off the steering wheel and use WD40? I assume to do that I must remove the crash pad which I don't know how to do?
Any advice would be appreciated. #annoying
Old June 6th, 2015, 10:46 PM
File it down a little. Common.
Old June 6th, 2015, 10:48 PM
wmatos1001's Avatar
wmatos1001
William
Thanks so just file back some of the plastic itself?
Old June 6th, 2015, 11:32 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
I would spray some silicone as you mentioned. Get a can that has a tube that you can stick into the area. Do that before going deeper into disassembly. Remember silicone is a lube, WD-40 is a solvent. This is a case for lube. (That's what she said).
90, wheel
Oiling a squeaky (heater) blower motor? dsh12 Defender Technical Discussions 4 October 29th, 2014 09:10 PM
Squeaky steering wheel wilyliang Defender Technical Discussions 15 March 27th, 2014 06:31 PM
Squeaky clutch george6 Defender Technical Discussions 3 December 20th, 2010 10:40 PM
Squeaky Shocks hutch Defender Technical Discussions 7 January 21st, 2010 09:08 AM
Squeaky Seat CDeWan Defender Technical Discussions 8 November 3rd, 2008 08:27 PM
