Squeaking breaks - Defender Source
Old January 31st, 2012, 07:37 PM
ADK46er's Avatar
ADK46er
Craig Longenecker
Squeaking breaks
So when will my breaks stop attracting attention when I stop?
I have had new rotors and pads on for a few weeks now and the squeaking is terrible. Ear piercing actually.
Old January 31st, 2012, 08:05 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
It depends a bit on what kind of brakes you got. Did you install yourself?
When I first got my truck a few months ago, it squeaked like a banshee. The front brakes were not installed properly... I think they were reversed. The back brakes were gone. Switched to all ceramic pads and now my truck is silent. I have also been told that that LR genuine pads that are hell-a expensive are softer and don't squeak. But I am happy with the ceramic aftermarket ones.
Old January 31st, 2012, 10:19 PM
jhhorse
joe heins
1995 defender 90
Craig, did you install your own pads? I would take the pads back out and add some grease to the back side and edges. If someone else did it take it back. Even the low end pads should stay quiet if installed properly.
Joe
Old February 1st, 2012, 03:32 PM
ADK46er's Avatar
ADK46er
Craig Longenecker
No, I didn't do the work. I will call the guy that did them and see what he says.
Thanks guys,
Old February 1st, 2012, 03:36 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
I had squeaky ones, but when I upgraded to EBC Green it went away...
Do you know if he put anti squeak goop on the back of the pads? Did he replace the pins (or at least clean them up)?
Old February 1st, 2012, 07:25 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
I have this same issue. I recently replaced all my pads and rotors as well, I was told by a local shop that would fix the initial squealing. So that's done and they still squeal, not as much but every now and then especially when making frequent stops and only at low speeds (5-0mph). It sounds to me like only the passenger side rear pad is making the noise. I did the job myself, got the whole brake kit; new pads, stock rotors, pins, springs, Ferodo shoes from AB. Didn't think of using any grease on the backs of the pads could this possibly stop the squealing? I've also heard that new brakes will do this until they're broken in.
Old February 1st, 2012, 07:53 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
+1 Here - did the same thing, keeps squeaking from 0-5mph. I took all the pads out, put copper grease on the backs, still squeak.
Next step is buying OEM pads and hoping for the best....
Squeaking... cord Defender Technical Discussions 17 June 2nd, 2010 07:35 PM
Squeaking sound in SW WestTexasDefender Defender Technical Discussions 4 May 8th, 2006 02:16 PM
