Squeaking... - Defender Source
Old August 7th, 2005, 07:48 PM
cord
Chris Ordway
95 D90 ST #2775
Squeaking...
Greetings all, picked up a 95 D90 a few weeks ago and since then it has developed a high pitched squeak coming from the front passenenger side, thought it was at first the rear tire carrier...Not the AC, occurs when I'm driving and can't hear the noise when the engine is idling...Think it may be door hinges??? Anyone have this problem?? or know how to fix it besides earplugs?
Old August 7th, 2005, 09:07 PM
Get some WD40 and start squirting things until the noise goes away. There are 58,236 things on my Defender that squeek, rattle, or make noise you just need to learn which things you should worry about.
Old August 8th, 2005, 12:05 AM
Once again, Mike is correct. It could be about 58,236 things. I would start with the door locks, hinges, seat rails, anything that is metal rubbing on metal. You may also want to try tightning seat rail bolts, roll bar bolts, etc...... Post some pictures of your new 4 wheeled money pit!
Old August 8th, 2005, 12:28 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
I have a list: tire carrier, rear door hinges, sliding rear windows, roll cage mounts, radiator cap rubbing on hood. Then there's the rattle list......
Doug W.
Old August 8th, 2005, 09:07 AM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
Just another thought... sometimes air leaking around the door can cause a high-pitched whistle that might sound like a squeak, hence why you only hear it while driving. If so, you can adjust the door so that it seals better.
Old August 8th, 2005, 09:18 PM
cord
Chris Ordway
95 D90 ST #2775
Thanks for the input...had already hosed down everything with WD-40, pretty much a no smoking zone as a result...will start tightening once the squalls subside outside...
Old August 8th, 2005, 11:02 PM
michael15's Avatar
michael15
Mike Schlueter
1995 Red D-90
Its not the brakes right?
Old August 9th, 2005, 09:42 AM
Kev Baldwin
Kevin Baldwin
2.4 Tdci 110 Utilty Wagon
Check the seat rails at the very ends of the rails. You'll notice the portion that bolts down into the seat box is a seperate piece/tab of steel welded (badly) onto the end of the main seat runner. It's common for the welds to fracture allowing the seat frame to flex and cause the annoying sqeaking you describe.
Kev
Old August 9th, 2005, 01:38 PM
Rover- Girl
Guest
Posts: n/a
Check for squirrles trapped under youre bonnet
Old May 15th, 2010, 10:31 AM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
AAGGGHHH! I have this noise too! I just installed a hardtop (thanks evilfij) and that was making noise so I had to trim & modify that, but now I have a sqeaking noise that is not hard top related- it seems to be coming from the dash somewhere? I already tightened everything I could find. Aarrgghh!
Old May 15th, 2010, 04:19 PM
j0nny216's Avatar
j0nny216
Jon Kleppel
1994 D90
I had the same problem and it was my seat rails causing it. As long as I had a passenger it was fine...
Old May 15th, 2010, 11:29 PM
I have this - keep forgetting to put a spot weld on the rail when I have the welder out. Easy to tell if that's your squeak wade - just reach over and put a hand on the passenger seat. If the squeak stops, the seat rail is separating.
Old May 16th, 2010, 12:36 AM
isleofman's Avatar
isleofman
Lee Davis
'95 D90 "BeastLee"
I have it too. in my case it's the breaks (right rear to be exact!!!) next little task i have to see to. always learing
Old June 2nd, 2010, 02:55 PM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
squeaking
I have a noise....happens when i turn or hit a bump..sounds more like a large metal object hitting a spring- I am in the middle of spraying the undercarriage as well....it has helped a bit.
Steve B-
Otterberg, Germany
"Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors."
- Hunter S. Thompson
Old June 2nd, 2010, 05:19 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Anyone figured out how to shut up the tire carrier? Didnt start until I took it off and now it wont quit.
Old June 2nd, 2010, 05:33 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Solution to all your problems = turn the know on the stereo to the right :-)
Old June 2nd, 2010, 07:18 PM
CDN90's Avatar
CDN90
Tim
94 / D90 #79
cord - sounds like your seat rail mentioned above...mine did the same, now it just clicks instead of squeaks. goes away when i slide the seat all the way forward (when driving). maybe try the same and see if it goes away.
Here's another: My clutch pedal squeaks ever-time i press it in and on the way out...its silly loud. It got even worse when i sprayed wd40 up in the hole were the clutch lever goes into the bulhhead!? I can't even see the spring in there...any ideas on how to get to it with out doing a frame off restoration?
Old June 2nd, 2010, 07:35 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
Another squeak from passenger side is (On roll up windows doors only) that the trim of the door rubs against the trim on the dash near where the grab handle is. If Im not clear enough Ill take a picture of the place.
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Squeaking sound in SW WestTexasDefender Defender Technical Discussions 4 May 8th, 2006 02:16 PM
