Squeak - Page 4 - Defender Source
Old July 24th, 2012, 11:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
MIght be time to sell it
Old July 25th, 2012, 12:15 AM
d90dan's Avatar
d90dan
Dan Berry
1995 D90
Had a d90 with a loud high pitched squeak. Couldn't pinpoint where it was coming from inside the car. Turned out to be the doortop rubbing on the hardtop.
Worth a look if you have a glass ht or st with gutter kit
Old July 25th, 2012, 12:36 AM
bjf's Avatar
bjf
barry f
94 ST #395
I have the soft top with the gutterkit. You think it could be the doortop rubbing the door seal?
Old July 25th, 2012, 12:55 AM
bjf's Avatar
bjf
barry f
94 ST #395
I will drive with my door open and see.
Old July 25th, 2012, 03:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
Not the door
Old July 25th, 2012, 05:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks to Nikojo I have solved the squeak that over the last 5 years has gotten worse and driven me to the point where I never wanted to drive the truck. It was the hood plastic bushings. I just lubed them up and the noise is gone. I am shocked. When he told me I said no fucking way. I just greased it up and the noise is gone. I'm not sure if bushings are worn but I have a new set I will swap in when I have time. Right now the grease is on and now I can obsess on why my exhaust rattles at 2000 rpm.
Old July 25th, 2012, 05:51 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Originally Posted by bjf View Post
...now I can obsess on why my exhaust rattles at 2000 rpm.
If it's a Borla, I have the same deal. There seems to be a resonance at 2000 rpm and it buzzes.
Old July 25th, 2012, 06:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yes borla. I removed my exhaust and y pipe to put in my new clutch. I replaced the gaskets, and the rubber exhaust hangers. Now of course it rattles. It sounds like a heat shield rattling.
Old July 25th, 2012, 09:40 PM
Take a pic o that bushing. I oils swear I heard the same shit in my truck tonight, but it sounded like the rear tire carrier to me. The sound bounced around a little though.
Old July 25th, 2012, 10:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
Its a little piece of plastic. Check the RN site. I swore it was my tire carrier for a long time then the seats, then the dash and it was the stupid hood. Drove a bunch tonight and not a single squeak.
Old July 26th, 2012, 12:16 AM
Bludog66's Avatar
Bludog66
Scott Hoskin
1994 Defender 90 ST #1108
I thought that might be the source on mine. So I ordered them plus two more bonnet parts from RN. Attached are the part #'s and prices. We'll see next week if anything works.
Also my first time attaching photos from my iPhone see if this works.
Old July 27th, 2012, 01:43 PM
slowpoke496
Bryan
94
Oh man. I have had the same squeak for the past 4 years and purchased those bushing a week ago and have not yet installed them. I also replaced all of the tire carrier rubber and bushings and lubed up the passenger seat.... i hope it is those bushing for me too.
Old August 12th, 2012, 12:21 AM
Bludog66's Avatar
Bludog66
Scott Hoskin
Replaced the bonnet bushings today and the squeak is gone!!! Now I can hear all the other rattles.
Old August 27th, 2017, 07:38 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Holy shit I have been going crazy trying to find this squeek for months. It sounds just like that, it sounds like it coming from inside the dash below steering wheel by fuse box kinda, I took apart the entire upper dash drove around, still there. I thought it was the vents, lubed it all up, still there. It sounds just like that around clip. I need to check this out
Edit - Just greased them up, went for a rough ride with the lady. Not a peep. I feel like I just won the Defender lottery.
Front wheel squeak bjf Defender Technical Discussions 15 December 6th, 2010 03:53 PM
Clutch Squeak Bozman Defender Technical Discussions 6 August 27th, 2009 11:18 AM
Rear brakes(?) squeak under load kolvedic Defender Technical Discussions 3 June 25th, 2007 03:17 PM
Shutoff Squeak Jon_Winningham Defender Technical Discussions 1 January 23rd, 2007 03:46 PM
Wicked Squeak ronward Defender Technical Discussions 1 July 16th, 2004 03:39 PM
