Squeak - Page 3 - Defender Source
Old July 22nd, 2012, 09:28 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by cgalpin View Post
For the front nothing. Just pull it, then drive and see if the noise goes away. After putting it back in, remove the rear and lock the center diff and drive and see if the noise goes away.
Will try it.
Old July 23rd, 2012, 03:49 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Barry,
Does it sound like this???
Old July 23rd, 2012, 04:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by tjfslaughter View Post
Barry,
Thanks Tom for posting it. That is the sound coming from my truck.
Old July 23rd, 2012, 06:57 PM
I vote seat rail
Originally Posted by pendy
I'm here for the D's
Old July 23rd, 2012, 07:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
I vote seat rail
Definitely not a seat rail. Replaced my frames thinking it was the cause. Same noise still happening.
Old July 23rd, 2012, 07:28 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I don't know what it sounds like but my recommendation is to check out your u-joints on both drive shafts. I had a chirp around 10-20mph 2nd or 3rd gear. Thought it was a front u-joint but was on the rear drive shaft. Took me a while to hunt it down when at first I thought it was something in the cab.
You little rebel, I like you.
Old July 23rd, 2012, 07:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah I am thinking front but never know could be the back.
Old July 23rd, 2012, 08:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
Just greased both driveshafts and the squeak is still there. They both look ok but no clue.
Old July 23rd, 2012, 08:38 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Is there any play in any of the u-joints?
Old July 23rd, 2012, 08:50 PM
bjf's Avatar
bjf
barry f
94 ST #395
Not that I saw. I could rock the front back and forth but the ujoints didn't rock it was more of play in the diff or parking brake.
Old July 23rd, 2012, 09:22 PM
True story vibration boom rattle in. Buddy's jeep by the mirror traced to a twig between chassis and body creating a vibration that transmitted itself and came out by the mirror.
Morale: don't be afraid to go outside the immediate area to find the cause.
Old July 23rd, 2012, 09:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
Honestly been looking everywhere.
Old July 23rd, 2012, 09:55 PM
Can't think of anything in the interior aside from the seat rails that would make that sound. Sounds more like rear tire carrier than anything else to me. Dismount the spare and see if that does anything.
Aside from that, I'd guess you've probably already found the issue, but greasing it didn't fix it.
Old July 23rd, 2012, 10:07 PM
Yeah I was going to say I'd laugh if it ends up being the Yakima!
Old July 23rd, 2012, 10:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
I've driven without the carrier and it made the noise. I originally thought it was coming from the back.
What seat box bolts?
Old July 24th, 2012, 04:53 PM
bjf's Avatar
bjf
barry f
94 ST #395
Any other ideas other than driveshafts?
Old July 24th, 2012, 05:23 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Why don't you just go get a shop to check out your u-joints. They will either say they are fine or say one of them or more need to be rebuilt. It is a cheap fix and doesn't take more than an hour.
Old July 24th, 2012, 06:26 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
just read through this and my 95 never made a sound then one time out in the desert offroading and it made a squeak that resembled yours -a nd continued to make that noise - seemed to be worse when the truck hit a little bumpy road - drove me crazy - felt like it was coming out of the dash never found the culprit - sold the truck and solved the problem
Old July 24th, 2012, 07:03 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
This might be a long shot but my '97 made a similar high pitched chirping that turned out to be the idle tensioner. I know the tensioner on a '94 is different but I would suggest checking and seeing if that isn't what's emitting that squeak. I removed my tensioner and sprayed the shaft the pulley wheel spins on with some wd40 or blaster and it went away.
Old July 24th, 2012, 09:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will try it.
Front wheel squeak bjf Defender Technical Discussions 15 December 6th, 2010 03:53 PM
Clutch Squeak Bozman Defender Technical Discussions 6 August 27th, 2009 11:18 AM
Rear brakes(?) squeak under load kolvedic Defender Technical Discussions 3 June 25th, 2007 03:17 PM
Shutoff Squeak Jon_Winningham Defender Technical Discussions 1 January 23rd, 2007 03:46 PM
Wicked Squeak ronward Defender Technical Discussions 1 July 16th, 2004 03:39 PM
