Squeak - Page 2 - Defender Source
Old July 19th, 2012, 11:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by jefferson View Post
I had a nasty rattle/squeek coming from the passenger side, but closer to the wing. Turned out to be the bonnet prop rod. When the hood was down and the prop folded, it would squeek. I pulled the pin and stacked a few nylon washers in where it meets the hood and that solved it.
How did you find it? Did it sound like it was coming from in the truck?
Any idea what to use to record it?
Old July 19th, 2012, 11:45 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
I just kind of went around the general area that I thought it was coming from and used the palm of my hand to lightly bang on each part/panel until it revealed itself. It was obvious when I got to the hood.
Old July 19th, 2012, 11:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Going to look now but I still think it is in the truck.
Bludog66's Avatar
Bludog66
Scott Hoskin
1994 Defender 90 ST #1108
I have what sounds like this exact same thing. Sprayed WD40 on the outside of the passenger door hinges and that seemed to stop it for a while but it's back again and I'm running out of WD40. I'll be interested to hear the solution if there is one. I'm going to check the bonnet prop now.
Old July 20th, 2012, 12:41 AM
bjf's Avatar
bjf
barry f
94 ST #395
I just checked the prop and it seems fine but I lubed it up anyway. The hinge is lubed up and the noise is still there. It's painful at this point.
Old July 20th, 2012, 12:11 PM
Check the hood.
Does speed or bumps have any impact on it?
I've had the hinges on the bulkhead squeak when the hood wasted latching properly, drove me crazy for a while.
Old July 20th, 2012, 01:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by rover4x4
Check the hood.
Did it sound like it was in the truck. That is the weird thug. Sounds like it is inside somewhere
Old July 20th, 2012, 05:56 PM
drsmiley's Avatar
drsmiley
Roger
97 ST
Mechanic called it "Windsor polylube" it appeared to be GEL like in aerosol can. not liquid like wd40
Old July 20th, 2012, 07:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will look for it.
Old July 20th, 2012, 08:43 PM
It was just squeeky and extra annoying. Is your battery tied down properly?
Old July 20th, 2012, 09:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah checked the battery too
Old July 20th, 2012, 11:41 PM
It's probably your rear crossmember about to fall off, or knowing your truck, two pieces of rust rubbing together.
Old July 21st, 2012, 12:00 AM
bjf's Avatar
bjf
barry f
94 ST #395
Not that either. Think inside the truck or comi g through the dash.
Old July 21st, 2012, 08:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
Just drove around and it was described as a high pitch chirping. Could it be my driveshaft?
Old July 21st, 2012, 09:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by JSBriggs
When was the last time you lubed your Ujoints? If the squeak goes away, call it a band aid until you replace them.
-Jeff
Never. Will try
Old July 21st, 2012, 09:45 PM
-Jeff
Dude. Nice avatar. Hahaha.
Old July 22nd, 2012, 09:14 PM
Remove them one at a time and see
Is it you Josh?
Originally Posted by pendy
I'm here for the D's
Old July 22nd, 2012, 09:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
Is it you Josh?
It wasn't the hood but it for sure sounds like it is inside the truck. I guess the driveshafts could sound like they are in the truck. It doesn't happen at slow speed. I have to be in at least 2nd or faster. If I remove them one at a time then what?
Get yourself a stethoscope pull the disk bit off the end and it creates a super directional noise locator.
Old July 22nd, 2012, 09:27 PM
For the front nothing. Just pull it, then drive and see if the noise goes away. After putting it back in, remove the rear and lock the center diff and drive and see if the noise goes away.
Front wheel squeak bjf Defender Technical Discussions 15 December 6th, 2010 03:53 PM
Clutch Squeak Bozman Defender Technical Discussions 6 August 27th, 2009 11:18 AM
Rear brakes(?) squeak under load kolvedic Defender Technical Discussions 3 June 25th, 2007 03:17 PM
Shutoff Squeak Jon_Winningham Defender Technical Discussions 1 January 23rd, 2007 03:46 PM
Wicked Squeak ronward Defender Technical Discussions 1 July 16th, 2004 03:39 PM
