square tube for winch spacer? - Defender Source
Old February 10th, 2012, 09:57 AM
Abrooks's Avatar
Abrooks
Tony Brooks
So I'm mounting an 8274 onto an ARB bumper. The challenge is that you need to space the winch back 1.5" to clear the bottom rail of the brush guard. There's a good write up in the tech articles section in which the author specifies using Aluminum block to do this. My political science degree didn't cover much metallurgy, so I'm wondering if I can use some aluminum or steel tube that I have lying around or if the spacer needs to be solid to avoid (for lack of a better engineering term) getting crushed.
Any thoughts?
Old February 10th, 2012, 10:02 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Solid is ideal, but but required. You'd have to be working at extreme loads far beyond the capacity of the winch and weight of your truck to crush 1.5" square tube (unless it's REALLY thin wall). My suggestion is to sleeve the holes. If you want, get it all cut and roll down to my place and I'll weld in the sleeves.
Semper Fi!
Old February 10th, 2012, 10:04 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, I may take you up on that!
Old February 10th, 2012, 10:06 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I would think you could get away with some heavy wall tubing, especially if you sleeve the mounting holes.
Like you, I was planning to install an 8274 on my ARB bumper before changing to a Rockware bumper and still have the blocks of aluminum in the garage that I will sell you for what I paid...pm if interested.
Old February 10th, 2012, 10:46 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
I used chunk of aluminum bar for a past bumper. solid and light.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
ac, winch
Tdi intercooler tube diameter artm Defender Technical Discussions 1 December 30th, 2005 12:13 PM
New style breather tube!! 48vphantom Defender Technical Discussions 1 August 7th, 2005 09:05 PM
1" wheel spacer - borrow Jase Defender Technical Discussions 0 July 16th, 2005 05:23 PM
Square D-90 clock easy Wanted 9 May 8th, 2005 09:33 AM
94 Square Tail lights switch to 95/97 ?? mfreeman17 Defender Technical Discussions 12 May 17th, 2004 04:58 PM
