sqeaking - Defender Source
Old September 11th, 2006, 10:24 AM
sqeaking
I have a new sqeak, that I cannot seem to find or kill. It sounds like it is coming from one of the rear wheels. It started after a trail ride in Uwharrie at the end of april. I was pretty muddy, so I assumed it was dirt somewhere.
I started by taking the wheels off and pressure washing the entire under carrige and suspension. I took off my trail tires and put on my other set, no changes.
I have checked and rechecked the search section. I have hosed everything down with WD40 and White lithium grease, but still no changes. I even sprayed down the bushings, just in case.
On Friday, I regreased the bearings and even replaced them on the passanger side. I looked at the break pads and they looked fine, as did the rotors.
The noise is most noticalbe when I am coasting. It seems to go away when I have my foot on the gas.
Any thoughts or help would be appreciated.
Old September 11th, 2006, 10:46 AM
i seem to have crickets somewhere in my SW. Not sure where it just started one day. Its impossible to find.
