Sputter & Stall - Defender Source
Old January 4th, 2016, 10:06 AM
bdavis2188
1997 D-90
Sputter & Stall
My D-90 has been running great but on a recent start it began sputtering and went to stall out with more acceleration. It starts fine and idles great. The sputtering increases with the amount of gas I give it.
I ran a diagnostic and the following fault codes appeared:
P1190 Oxygen Sensor Heater Type 2 Low Resistance Upstream
P1187 Oxygen Sensor Heater Circuit Short Upstream
P0157 Oxygen Sensor Low Voltage *Codes* B D
P1317 ABS Rough Road Line Low Fault
P3999
Any idea what is causing this? Is this a major issue?
Please help!
Old January 4th, 2016, 10:19 AM
Judging by the fault codes and your description have you started with the oxygen sensors? I believe the 1997s have both pre-catalytic converter sensors and post-cat sensors, for a total of 4.
Old January 4th, 2016, 10:54 AM
bdavis2188
1997 D-90
Thanks! I'll start there
Do you happen to know if there is a big difference in the parts? I found these for $264.00 for a set of 4 made by Walker
97 1997 Land Rover Defender 90 Oxygen Sensor - Fuel Injection - Bosch, Denso, NGK, NTK, Walker, Downstream, Downstream Left, Downstream Right, Upstream, Upstream Left, Upstream Right - PartsGeek
Also found Bosch for $343 for a set of 4 and a kit on Rover Parts for $429 (Rover Oxygen Sensor Kit - Discovery, D90 And Range Rover)
Old January 4th, 2016, 11:22 AM
O2 sensors do not come into play until after the engine has gone thru initial warm up period. If it is sputtering on start up it will not be o2 sensors.
Stumbling on acceleration I would first look for vacuum leak, bad TPS, Bad IAC. Stumbling usually bad fuel mix (starvation) from air leak or other anomoly.
Old January 4th, 2016, 11:26 AM
Or bad catalytic converter(s) (therefore fouling the O2 sensor(s)), no?
Old January 4th, 2016, 11:33 AM
You can run just fine without O2 sensors even being connected, so prolly not, unless the cats are clogging the exhaust which is also a possibility.
Old January 4th, 2016, 12:46 PM
bdavis2188
1997 D-90
any way to test this to see where the trouble is before I drop the cash on the O2 sensors?
Old January 4th, 2016, 11:48 PM
Departing90
Sasha
95 D90
Whooooa......
If tye issue is indeed O2 sensors they NEVER all go bad at the same time!
Often times there are residual codes in the ecu or anomalies of different kinds for multiple codes to come up but not unheard of. The proper cource of action is to clear tye codes, wait tye check engine light to illuminate tyen read them again to confirm.......
Old January 5th, 2016, 12:28 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would Agree with Bill. Particularly a vacuum leak.
Old January 5th, 2016, 03:24 PM
bdavis2188
1997 D-90
I have it in the shop now... we shall see about the vacum leak and O2 sensors but my mechanic says the wires are arcing and he is replacing them, the plugs, and cleaning out the throttle body as a 1st COA
Old January 5th, 2016, 04:35 PM
wow preventative maintenance
4.0 Intermittent Sputter/Stall Wolf Fabrication Defender Technical Discussions 4 May 7th, 2013 04:25 PM
TD5 Intermittent Sputter Kelbo Defender Technical Discussions 25 February 20th, 2013 09:36 PM
OPen loop stall, or at least I think it is open loop! Neo Defender Technical Discussions 18 January 25th, 2012 11:34 AM
Sputter, cough, die. wcampbel@nas.edu Defender Technical Discussions 12 August 29th, 2010 08:53 PM
Gurgle, Burp, Sputter, and Wheeze boshea Defender Technical Discussions 12 July 6th, 2004 02:44 PM
