Spun Bearing? - Defender Source
Old June 26th, 2007, 09:02 AM
Lee
Lee O
95 NAS D-90 300Tdi
Spun Bearing?
I think I've got a spun bearing - rattle, not a whine.
300tdi to an R380
I thought it might be the TO bearing (rough noise location) but it doesnt matter if the clutch is pushed in or not. The noise occurs when there's no torque on the drive train - when I lift off the accelerator. The noise stops if I brake or reapply the accelerator. It also seems road speed dependent, not engine speed. I need to be going around 50+ for it to happen.
Thanks for any help.
-Lee
And yes, I've thought about having one foot on the brake and one on the accelerator (to paraphrase Sammy Hagar).
Old June 26th, 2007, 11:21 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I'm thinking spring rattle or driveline vibration/driveshaft problem more that engine/transmission. Are you running lift springs? If so, how much lift?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 26th, 2007, 11:37 AM
Lee
Lee O
95 NAS D-90 300Tdi
Spun Bearin?
The rest of the setup is:
Rovertym 2" springs (RR3-2)
SG 3-link
Fox eye-eye shocks
32" tyres
thx
-Lee
wheel bearing D90user Defender Technical Discussions 15 April 17th, 2006 09:35 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
Rear wheel bearing damage potential?? Neo Defender Technical Discussions 8 November 28th, 2004 11:58 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
