Springs not sprung - Defender Source
Old April 16th, 2004, 04:01 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Springs not sprung
Ok so I got from Mike that I need to take the shocks off to get the springs off. Trouble is i can't stop the shock from spinning when I try to take the nuts off. Any ideas tricks? Oh and I'm finding a lot of mud from Rausch Creek still.
Jimmy Buffett
Old April 16th, 2004, 04:15 PM
The top of the shock should have a notch for a screwdriver or it should be square to put a wrench on it.
Old April 16th, 2004, 04:53 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Heat the nut to burn off any lock-tite or nylon on the nuts.
Use an adjustable wrench to old the flat spots on the stud until the nut works loose.
Stock shocks had plastic "boots" and you cant grab them like you can with OME shocks and a pipe wrench.
It that doesn't work, use a grinder or saws-all
--Benjamin Franklin
Old April 16th, 2004, 04:55 PM
flippedrover
Tyler
'94 D-90
thanks. I'm working back to front now so that I can feel like i've accomplished something today.
Jimmy Buffett
Old April 16th, 2004, 05:02 PM
I like that method the best!
Old April 16th, 2004, 05:07 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
I've used channel locks in the past. On OME shocks there is a serrated ring at the base of the each shock in which I affix the channel locks to a the while using a ratchet to remove the nut.
DJ
Old April 16th, 2004, 09:19 PM
flippedrover
Tyler
'94 D-90
I've got Bilstiens. Got the back done and the truck rides a lot better. Going to tackle the front tomorrow now that I'm getting a bunch of tricks to try.
Jimmy Buffett
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
new springs? scoloco Defender Technical Discussions 4 April 5th, 2004 06:08 PM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
