Springs & Shocks Install Tips - Page 2 - Defender Source
Old April 27th, 2007, 01:33 PM
i am guessing you removed your shock towers through the engine compartment?
Old April 27th, 2007, 07:57 PM
fuck me. having the right tools and equipment really make things a lot easier.
Old April 28th, 2007, 09:10 AM
how did you get the nut off the front shock? ive gotten the shock and shock tower out with ease.
Old April 28th, 2007, 09:33 AM
Andrew Vick
Andrew Vick
95 D90
Cut it off and replace with new.
Old April 28th, 2007, 06:52 PM
reflections
I completed the install of the standard OME HD/MD suspension. The 751 in the front 764 rears, with OME shocks. The ride is about the same as stock. I am currently running without the front sway bar and under normal circumstances has as much body roll as the stock suspension with the rear removed. I think that a highspeed manuever or overcorrection would be very dangerous at highway speeds. I will most likely reattach the front swaybar for saftey, although it really flexes a lot more offroad. I installed the rubber shock tower rings and the rubber donuts on top of the rear springs, they dont seem to make any difference. I still have stock tires and the truck doesnt look to bad but new tires are in the future. The truck sits a little higher in the rear, I think it is leaning high on the PS. I did not take any measurements before or after. This can be done with a highlift jack (borrowed) one jackstand (borrowed) the stock bottle jack proved to be very useful although it is not essential. Vicegrips and a pipewrench were very useful and a butance torch to burn out the nylock nuts on the front shock tower. This was the hardest part of the operation. Use a plenty of PB blaster the week prior. Put on your favorite Grateful Dead show and go at it. It was fun to do. So far I have not noticed any vibrations, I have not been over 60mph yet so that will be determined. In hindsight I might have just put on the OME shocks and LR HD springs with the little rubber donuts on top and bottom. Hope this helps someone I know it took me three years to finally get this done.
Old April 28th, 2007, 07:48 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
what were you saying? I can't even concentrate on your post! I mean, damn.
Old April 29th, 2007, 12:41 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yeah, stick to small words. Short sentences.
Old April 29th, 2007, 08:23 AM
Andrew Vick
Andrew Vick
95 D90
Could it be the avatar getting to you?
Old April 29th, 2007, 10:16 AM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Yeah, that avatar was messin' up my brain! Get two or three posts on one page with that "flopping boobs" avatar and I'm toast.
Old May 12th, 2007, 10:11 PM
On furthur evaluation the truck drives like shit wanders all over the road, leans to the drivers side and has driveline vibrations. A stock Defender is hard to beat.
Can I Get Softer Shocks and Springs? EdF Defender Technical Discussions 1 January 6th, 2006 03:27 PM
Lokking for shocks and springs or spacers Vadim Wanted 1 July 7th, 2004 05:26 PM
OME Springs and shocks Seanh Wanted 3 June 14th, 2004 10:13 AM
Front shocks outside of coil springs? castlerock4x4 Defender Technical Discussions 19 May 12th, 2004 04:23 PM
Springs and Shocks loykd Misc. Chit-Chat 18 April 20th, 2004 11:41 PM
