Springs - Defender Source
Old May 16th, 2013, 07:32 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Springs
Ok guys after nearly 2900 miles on the vacation I am thinking I would like to get a little smoother ride out of my truck and maybe a little lift. What is the best way to go? I don't plan on wheeling very hard and wouldn't want to lift it more than 2 ".
What's the best kits or brands to check out?
Thanks in advance.
Abe
Old May 16th, 2013, 07:43 PM
Aftermarket spring will make the ride worse.
Old May 16th, 2013, 07:56 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Look into the spring rates of what you have v what you are considering. Many aftermarket springs have higher rates resulting in a harsher ride but greater carrying capacity. Single rate v progressive makes a difference. Red90 has a good reference page for spring data.
1970 SIIA 88, Sold
Old May 16th, 2013, 08:14 PM
solarguy's Avatar
solarguy
Abraham Bell
I don't want to really carry any more just want a little softer ride. I would have thought that an ex mod truck would be easy to improve the ride.
Old May 16th, 2013, 08:17 PM
There may be some choices, but normally the stock springs are the softest. I do not think the MOD trucks use different springs than the civilian ones. You might be able to get softer shocks.
Have a look and post up what springs you have.
Old May 16th, 2013, 08:19 PM
solarguy's Avatar
solarguy
Abraham Bell
Ok I will see what I can find.
Old May 16th, 2013, 08:21 PM
jafir's Avatar
jafir
Jafir Elkurd
Based on the list on your web page, my mod truck has OE HD springs, at least in the back. I haven't been to the front yet. It's probably because it would be loaded down with batteries and radio equipment 99% of the time.
Old May 16th, 2013, 08:34 PM
solarguy's Avatar
solarguy
Abraham Bell
Lets say that they are oe hd spring would a standard duty achieve what I am looking for?
Old May 16th, 2013, 08:45 PM
tpond
Toby Pond
110
What about keeping the stock springs, but adding some mild spacers to bring it up a little?
Old May 16th, 2013, 08:57 PM
110 rears are always stiff as they are intended to be loaded. The ome light duty ones are longer and lighter than stock. Koni shocks would help as they have a soft ride.
Old May 16th, 2013, 09:23 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Try these to find out what you have, that is if you can still see a color code on your springs.
http://rovers.red90.ca/springinfo.html
http://www.landroverclub.net/Club/HT...ing_rates.html
Old May 16th, 2013, 09:52 PM
Stock range rover classic non-eas springs are the softest and nicest ride.
Old May 17th, 2013, 06:37 AM
Capt Milks's Avatar
Capt Milks
The problem is going to be that he has to match the fronts and the larger 110 rears. Also if he has a heavier diesel engine it will change the load on the front spring compared to the V-8's. I like the progressive front springs on my 110.
Old May 17th, 2013, 09:21 AM
Defenders are lifted more than RRs and Discos stock so have heavier springs.
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
new springs? scoloco Defender Technical Discussions 4 April 5th, 2004 06:08 PM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
