Spring spacers - Defender Source
Old July 22nd, 2004, 10:31 AM
rvrchuck's Avatar
rvrchuck
Chuck Hester
1995 D90
Spring spacers
Currently running OME Med fronts and OME HD rears...only 1-1.5" of lift. Thinking about adding the 2" CNC spring spacers for 3-3.5" of overall lift. Other than articulation limitations, is there anything else I should be worried about by adding these things (other than driveline/pinion angle correction issues which will be addressed when I lift).
Roverin' Chuck
'95 AA Yellow 90
Old July 22nd, 2004, 11:47 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Well,
Why are you going spacers instead of springs? With that high of a spacer you are going to get a lot of lateral movement out of the spring. Causing fatige and maybe failure. The other thing is you will have to address the radius arm ange at that height. Your Down travel is going to be seriously limited unless you do a lot to address it. Also, why so much lift? Anything over 3in is not necessary unless you want to run tires bigger than 37's. My guess is that you want 35's which is the largest that the stock axles can handle after you upgrade everything. In that case, use a .5 or max 1in spacer and you will be fine.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 24th, 2004, 10:40 AM
Slunnie
Simon
If the spacer is under the lower perch, it also worth checking the clearance of the top of the spring against the chassis rail during full articulation on the front. It may rub on the sides. The spacers will also increase the effective spring free length and then you are looking at longer shocks to match, bump stops, brake extensions possibly etc. Good on you if you make it happen I say.
Old July 29th, 2004, 03:56 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
I wouldn't even consider doing that. But I run stock springs, so don't listen to me.
Old July 29th, 2004, 10:46 AM
redrover
Guest
Posts: n/a
Chuck, if you want the large spacers up front, you will need to use a adapter of some sort on the bottom shock mount. And convert to a eye/eye shock. If you are going to retain the stock shock , I think you can only get a 1/2inch spacer under spring due to the stud lenght. Anyway , If you put 764md sp all around, you get close to 3inches. JP
ac
Spring spacers CDeWan Defender Technical Discussions 11 December 3rd, 2008 01:32 AM
spring spacers d 90 CDeWan Wanted 2 October 31st, 2008 01:08 PM
anyone know a good source to pick up some 1 or 2" spring spacers? rgrrvr Defender Technical Discussions 1 May 7th, 2007 12:34 PM
1.5" spring spacers lwg Wanted 0 February 1st, 2005 02:56 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
