Spring replacement - Defender Source
Old May 24th, 2010, 04:41 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
Spring replacement
Anyone have a trick for getting the shock towers to line up with the holes for the retaining bolts? Gas shock is pushing things apart and generally annoying me. Another set of hands would be great, but not available...
-Gardner
Old May 24th, 2010, 04:53 PM
jack the truck up so that the axle drops-pulls shock downward
Old May 24th, 2010, 08:54 PM
rachet strap on top of the shock tower.
Old May 24th, 2010, 09:23 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
I put jackstands under the frame and then I use the bottle jack - first to spread the axle and then to raise the axle up to the new spring.
Old May 24th, 2010, 11:05 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
I think Ron gets the prize here. Plenty of drop to the axle from jacking; the shock, fully extended, (gas charged, so it does that naturally) is long enough that I need something to compress it while I'm trying to line up the retaining bolts. So, I'll try that. Thanks guys!
Old May 25th, 2010, 12:24 AM
"ron good"
Old May 25th, 2010, 10:09 AM
you switching out those 3 inch springs ?
Old May 25th, 2010, 11:49 AM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
exactamundo. Going with OME 761 & 758/764. Curious to see if there's any real difference. I may keep the Terrafirmas for Moab in October. If not, there'll be a post here
Old May 27th, 2010, 12:46 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
ratchet straps
did the trick. Piece of cake once I was schooled
ac
Need D1 rear spring perch James Wanted 1 April 3rd, 2005 12:29 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
