Spring Perch Alignment?? - Defender Source
Old May 19th, 2008, 02:02 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
So I am sitting in the driveway taking the hub apart to re-grease the chocolate, rust colored bearings and I noticed the bottom and top spring perch are not aligned at all. The bottom is about 2 inches further forward then the top. The shock is slanted forward and is relatively close to touching the cone. Seems wrong to me. I have the stock radius arms with a 2 inch lift. Is everyone else's front suspension sit square? The car was sitting level when I took a look at it. Any thoughts?
Old May 19th, 2008, 03:31 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Just made the same observation yesterday on mine. I have RTE radius arms and have the same conditions- about 2inches forward on the bottom. Don't recall if it was like this with stock arms. Mark
alignment
Front spring retainers, where? artm Defender Technical Discussions 11 September 17th, 2005 01:12 AM
Labor Time on Spring and Shock swap 1of40 Defender Technical Discussions 3 June 21st, 2005 10:01 AM
Need D1 rear spring perch James Wanted 1 April 3rd, 2005 12:29 AM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
