Spring lift - Defender Source
Old April 22nd, 2014, 07:38 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Spring lift
If my front coil springs measures 12 inches in height, while in the vehicle, how much above stock height does that work out to? Looks like maybe a 2" lift to me?
Old April 22nd, 2014, 08:02 PM
ssi19's Avatar
ssi19
scott
1995/D90
Show us a side profile pic of the truck. Probably easiest way to tell. Or measure fender flare to ground. Can compare to mine which is 2 inch lift.
Old April 22nd, 2014, 08:33 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Measure from center of wheel cap(or the hub cap) to fender flare for easy comparison
Old April 22nd, 2014, 08:56 PM
C391HAT's Avatar
C391HAT
Zach
86 110
May be different on a NAS vs ROW but what I used to determine the lift I had (or sag in the case of my front springs) is this:http://forums.lr4x4.com/index.php?sh...12#entry437086
The best way to measure your lift is to measure your spring heights with the
vehicle parked on level ground,measure from top to bottom of the rear of the
front spring,and the same for the rear spring,with quality springs you will
find that the drivers side is always slightly taller
STD 90/110 FRONT SPRING measures 260mm +/- 5 mm
The REAR SPRING should be around 300 mm +/- 10mm
Old April 22nd, 2014, 09:02 PM
Yes. Stock is around 10" front and 12" rear for a Defender.
How to tell if there is a spring lift? Brewie212 Defender Technical Discussions 0 July 30th, 2012 11:07 PM
spring wedges/spring spacers/A arm bracket crown14 For Sale - Parts 5 September 16th, 2011 12:50 PM
Spring Isolator and spacers, AKA the mini lift? Defender90_218 Defender Technical Discussions 3 July 26th, 2010 09:27 AM
Help me put together a Spring/Lift Measurement Database… LRNAD90 Defender Technical Discussions 9 April 15th, 2008 01:21 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
