Spray Paint Recomendations - Defender Source
Old December 19th, 2007, 10:36 AM
everglades
Nando Zorrilla
1995/Defender
People on this forum ofter refer to expoxy primer and spray paint but I have been unable to locate it locally other than the cans used for kitchen appiances, which tend to be in white.
Looking to blast and paint a bunch of the bit and pieces that are rusting.
Old December 19th, 2007, 10:41 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I like the Flat Black Rustoleum.
Old December 19th, 2007, 10:48 AM
I've had really good luck with everything I've ever painted with the expensive etching primer spray can from POR 15. For top coat, I've also had good luck with the custom spray cans from Tower Paint.
Old December 19th, 2007, 11:54 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
greg, why do you have pics of paint? i had to lol when i saw this.
Old December 19th, 2007, 12:01 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
To help make sure my paints stick well to metal I use a chemical metal etch first. I use Jasco. It comes as a concentrate - I mix a working solution in a used 409 spray bottle and apply it from the spray. It takes about a minute to work. You was it off - and dry. It removes all oils greases etc and puts a fine tooth to the metal so your primer or top coat . I use it on stainless and aluminum parts big and small.
Old December 19th, 2007, 12:58 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Ha ha,
I grabbed them off the internet. Yeah, yeah, that's what I did.
Old December 19th, 2007, 01:00 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I thought huffers used gold paint?
Old December 19th, 2007, 01:09 PM
Epoxy paint is available at lowes. Only comes in limited colors. Black, red, green, white, off white.
Ron
Old December 19th, 2007, 01:30 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
On this topic... What is the best way to prep metal that was originally powdercoated, but has some major flakes off and rusting on it for paint? Do I have to somehow sand blast/sand off the remaining powdercoat? or can I just hit the areas that are rusty, and assume that if the powdercoat is sticking, there is a good seal under it, and a full top coat layer will seal it up again?
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old December 19th, 2007, 03:13 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I just had my stop light bar sandblasted for $20 bucks.
paint
Alpine White Spray Paint wadaman Wanted 8 May 21st, 2009 02:58 PM
Arles Blue Spray Paint Wolf Fabrication Wanted 0 May 9th, 2009 11:36 AM
Spray touch-up paint group buy? JimC The Flea Market 88 April 8th, 2009 08:55 AM
touch up paint januconn92 Defender Technical Discussions 3 January 30th, 2007 10:01 AM
Paint a fiberglass hardtop? roverboy Defender Technical Discussions 5 December 12th, 2003 09:52 AM
