Spongy Clutch - Defender Source
Old November 27th, 2013, 06:41 PM
Spongy Clutch
Instead of hijacking the leaking clutch thread I figure it is better to start a new one.
My clutch is spongy after the vehicle sits for a few days. I pump the clutch about a dozen times and everything works fine. What should I be looking at or trying?
I hate plumbing projects!
Thanks!
Old November 27th, 2013, 06:52 PM
Spongy = air in line. You sure it's not leaking?
Mark Kellgren
KM4BOR
Old November 27th, 2013, 07:15 PM
No drips found but the reservoir was super low (I couldn't see any fluid when I opened it up).
After about a dozen clutch peddle pumps it is firm.
Old November 27th, 2013, 07:36 PM
Because fluid got low so air bubbles got pulled in past the piston. Refill, bleed and figure out where the leak is.
Mark Kellgren
KM4BOR
Old November 27th, 2013, 07:57 PM
Fluid is just disappearing so I'm guessing I need to swap out the slave.
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
