Splicing winch line - Defender Source
Old November 13th, 2012, 09:13 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Splicing winch line
Well went to put my 3/8x100' winch line on my winch. And as I was afraid of 100' is a little long....
So I guess I will be splicing the winch line. Going to have to find a new piece to cover the exposed line as well. Advice? articles?
Old November 13th, 2012, 09:24 PM
There are a bunch of how-to videos on YouTube.
Old November 13th, 2012, 09:34 PM
why not take it off and shorten from the winch end?
Old November 13th, 2012, 09:36 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
X2. Just trim off the end at the spool
Old November 13th, 2012, 09:44 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Damn... Unspool and respoll it is... But I guess you're right probably easier in the end to do it that way
Old November 14th, 2012, 06:41 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Before you cut, one thing you might consider is significantly reducing the length. How often do you spool out more that 50'? If rarely, you could shorten it to 50' and have a piece left over long enough for an extension. That would also give you closer to full power of your winch without having to spool off a lot of extra rope.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 14th, 2012, 10:21 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Shouldn't it be spooled under tension as well?
Old November 14th, 2012, 10:34 AM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
Brilliant
Old November 14th, 2012, 10:50 AM
This is what I did... And I had the hook replaced with a thimble.
Old November 14th, 2012, 11:11 AM
It is funny how things are different in other locations. I run 125' of line. Most of the time, I'm spooling out past 100'. I carry a 100' extension which gets used 1 in 5 pulls as well.
Old November 14th, 2012, 11:13 AM
Do you winch yourself back home?
Old November 14th, 2012, 02:16 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Thanks for the suggestions she has been trimmed to around 85' which I believe is normal for 3/8" and a 8500/9500 winch. I will see how it works once I get the axles put back together.. And will respool it under tensions as well which may make it fit a bit better. Just wanted to get it on there and ready to go for pulling people out of the ditch in the first snow storm. Got to pay it off some how
Old November 14th, 2012, 03:09 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Funny as shit
Old November 14th, 2012, 04:26 PM
fwiw splicing winch line is pretty easy. I removed the old the old hook from one of mine and put a safety thimble on and spliced the line back together. That was three years and a lot of winching ago.
winch
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
steel winch line rvrsrvc For Sale - Parts 0 February 15th, 2005 12:01 PM
synthetic winch line good or bad ripp2002 Defender Technical Discussions 1 January 18th, 2005 07:28 PM
Steel winch line NIB sheki For Sale - Parts 0 September 30th, 2004 05:43 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
