Speedometer Unstable - Defender Source
Old April 11th, 2014, 09:01 AM
richord
Richard Ordowich
1987/D90
I installed a new speedometer cable and new speedometer (removed the KPH and installed an MPH) and the needle is bouncing all over the place.
I was a bit leery of the new cable since it had a plastic shaft at the speedometer end while the old one was metal.
Is this a problem of the pickup gone bad?
I have a GPS with the speed displayed as a backup for now.
Old April 11th, 2014, 10:04 AM
Originally Posted by richord View Post
I installed a new speedometer cable and new speedometer (removed the KPH and installed an MPH) and the needle is bouncing all over the place. I was a bit leery of the new cable since it had a plastic shaft at the speedometer end while the old one was metal. Is this a problem of the pickup gone bad? I have a GPS with the speed displayed as a backup for now.
Yeah that setup is crap. Look at converting to a electronic VDO with YBE pickup. Plenty of threads on the subject if you search.
speedo
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
inaccurate speedometer artm Defender Technical Discussions 10 August 10th, 2004 11:33 PM
VDO Speedometer mgrgpg Defender Technical Discussions 6 December 17th, 2003 09:26 AM
» Defender Registry
DRAB
speedpin
Pumkin
natas
Add your Defender
