Speedometer question (NAS) - Defender Source
Old March 23rd, 2014, 10:50 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Will a speedo off of a 1994 D90 work on a 1997? Is there a way to make it work?
Old March 24th, 2014, 06:42 AM
No. Yes but you wouldn't want to do it.
Old March 24th, 2014, 07:25 AM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Well, my 97 speedo digital odometer almost never works. I have right at 71,000 miles on it now and found a 94 speedo for sale with 71,400 on it. Thought about picking it up if I could get it for the right price.
Old March 24th, 2014, 07:48 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Talk to these guys. I think they fix OE for shops like ECR and the like.
http://www.nhspeedometer.com/
FWIW, mine, also a 97, was acting up and went completely blank years ago. I figured I had nothing to lose so I removed it to take a look. I cleaned it and reinstalled it but I left it cockeyed to allow the ribbon in the back fully extend. Whatever i did seemed to do the trick. It works and I'm up to 128k. It does flash sometimes for no apparent reason but eventually it comes back. I think the problem with these is the ribbon is a bit too long and over time has trouble being kinked or folded up back there and needs to be shortened.
Clay
Old March 24th, 2014, 07:49 AM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Agreed, don't do it - there's a speedo shop in LA that will fix it for $300 or so. Search on speedo repair, you should be able to find it.
-Ren Ching
Old April 3rd, 2014, 02:00 PM
Nashville's Avatar
Nashville
Victor Hess
1997 Defender 90 NAS
The Hollywood Speedo shop quoted me $250. They did a great job previously on an old MB VDO speedometer.
1997 D90 ST NAS #1426
British Racing Green
VDO Programmable Speedometer Upgrade Question dsh12 Defender Technical Discussions 1 October 5th, 2012 05:11 PM
another speedometer question One Ten Defender Technical Discussions 2 March 13th, 2012 03:20 PM
Speedometer Cable question? Quimbola Defender Technical Discussions 15 November 12th, 2011 06:42 PM
Upper speedometer cable 94 NAS D90 Kilgore503 Wanted 10 February 18th, 2010 12:59 AM
speedometer question bharris Defender Technical Discussions 8 January 4th, 2008 05:13 PM
