speedometer question - Defender Source
Old January 3rd, 2008, 12:52 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
so newby here with a newly purchased d90 (one you guys have talked about here before with a 300tdi that I think pendy did the install on). I'm already having a great time with timing that's gone off (looks like someone didn't tighten it down properly) and I blew a gbr heavy duty cv as well (lucky me).
Now after that long winded introduction here's my actual question: My speedometer is consistently showing the speed as +10 mph from the actual speed and while it may be nice to think that I'm going that fast I'd really like to be a little closer to reality. It does have an aftermarket alternator which I think is making the rpms read too high but would this effect the speedo too? How does the speedometer work on these LRs? Is there any way to fix this?
Old January 3rd, 2008, 01:15 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Hey Brad, welcome to the board!
Do you have bigger than stock tires? If so, that's what causing it..
post up some pics of your truck when you get a chance!
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old January 3rd, 2008, 01:45 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
Speedo cable goes straight to the lt230 (center diff), if you have a analogy speedo there is a gear that drives it, you can change that gear and change your speedo to a more correct speed. Or you can install a digital programmable speedo that will do the same thing. Then you will need instead of a gear a electronic sending unit. This is how the new d90s are. VDO makes a great digital speedo.
Old January 3rd, 2008, 02:44 PM
bharris's Avatar
bharris
Brad Harris
I am running larger than stock tires (33") and have a change in the gearing (4.11) but the larger than stock tires should cause a percentage change not a consistant 10mph change and it should be the other way? Maybe the 4.11 gearing is putting it off?
It sounds like putting in a programmable speedo might be the best bet. I'll do some web searching. I'll look into VDO any other vendor recommendations? How tough will this install be?
and as requested, a picture of my new toy (if I can get the upload to work right):
Old January 3rd, 2008, 03:07 PM
pendy's Avatar
pendy
jim pendleton
89'd90
egauges.com Glad to hear it still burning fuel.
JP
legend in my own mind
Old January 3rd, 2008, 03:41 PM
rmuller
Ryan
Yeah, you're right, its the opposite with bigger tires, and that size shouldn't affect it much... On my disco2, stock tire size was 28, I have 33's on there now (and 4.11s).. when the speedometer shows 60, the gps shows ~68.
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old January 3rd, 2008, 04:02 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
its a defender thing, mine is out 10mph at any speed, thats when on the odd occasion its working
3rd low and BOOT IT
Old January 3rd, 2008, 05:57 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
You've go to make sure it's warmed up or at night to have an accurate reading.....
Welcome aboard Brad!!
Keith
Big, Red and ... aaa Red..
Old January 4th, 2008, 05:13 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Lookin' good Brad!
Chance
speedo
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Milage/ Speedometer calibration? oldscratchggf Defender Technical Discussions 3 January 3rd, 2006 03:59 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
