Speedometer / Odometer Not working - Defender Source
Old June 11th, 2009, 02:22 PM
TheBeast's Avatar
TheBeast
Dane Block
1994 D-90 #1440
Hey I just replaced my alternator (tach works now...) and my fan clutch on my 94 D-90, now my Speedometer and my Odometer are not working. I searched for info on this but could not find anything that seemed to help me out. How do I know if it is a bad speedo, a bad speedo cable or something else that may have happend when I fixed the ALT and fan clutch? The Speedometer just stays at zero and the odometer drum does not roll.
Old June 12th, 2009, 05:15 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Dane if you have a mech speedo, the drive cable has most likely snapped or is pinched.
remove the end of the cable at the transfer box and spin the inner cable with your fingers, you should see the speedo needle move.
The inner of the cable should be free to rotate, a gentle tug on the end will show if it has snapped.
regards
Gren
Old June 12th, 2009, 05:19 PM
redrockrover's Avatar
redrockrover
Russell Phillips
1994 Defender 90
I had the speedo cable come off the back of my speedometer. They can fall off very easy. I would take the instrument panel off and make sure the speedo cable is on the speedometer good.
Russ
'94 AA Yellow
# 891
Old June 12th, 2009, 05:37 PM
bjf's Avatar
bjf
barry f
94 ST #395
why would a speedo be jumpy at low speed?
Old June 13th, 2009, 09:08 AM
Resistance in the cable tube. Lube it up and it should go away (or replace the cable). My 110 needle jumped a good 10-20 mph either way until I replaced the cable (it finally broke). Not it just has a slight vibe.
speedo
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
Odometer reads 76% actual miles stevewhitaker Defender Technical Discussions 4 January 21st, 2006 06:07 PM
Milage/ Speedometer calibration? oldscratchggf Defender Technical Discussions 3 January 3rd, 2006 03:59 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
