Speedometer not working... - Defender Source
Old July 25th, 2016, 11:16 AM
Hello all,
I just recently purchased a 1985 D90 and the speedometer is not working. All of the other gauges seem to be working just fine. We have checked the connection behind the dash, into the speedometer and it seems to be fitting fine. Any suggestions or advice?
Old July 25th, 2016, 12:15 PM
It is a cable drive. You need to check both ends of the cable and the cable itself as well as the speedo to see what is broken.
speedometer not working TexasD-90 Defender Technical Discussions 5 June 1st, 2011 05:45 PM
Speedometer / Odometer Not working TheBeast Defender Technical Discussions 4 June 13th, 2009 08:08 AM
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 06:27 PM
'95 Factory Radio Fade/Treble/Bass Button Not Working gamberik Defender Technical Discussions 1 March 30th, 2005 12:05 PM
Fan blower switch not working draaronr Defender Technical Discussions 3 August 24th, 2004 10:26 AM
» Defender Registry
Add your Defender
