speedometer not working - Defender Source
Old January 25th, 2011, 09:06 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Some of you may have read and responded to my post about shredding my rear diff (thanks for the help). The same time that happened, I lost my speedometer and my odometer. Any suggestions? The cable was replaced in May, and is attached firmly to the speedometer gage itself. What should I check next?
That is why it is called a short cut. If it was easy it would just be "the way."
Old January 25th, 2011, 09:08 AM
take the speedo head off ... drive down the road and see if it's turning ... that way you can check the the lower components are working.
Old January 27th, 2011, 02:01 PM
Defender90_218's Avatar
Defender90_218
Trenton Smith
1997 D90
When I blew my windshield wiper fuse, it killed all my gauges. These things are wired kinda nutty.
Old January 27th, 2011, 02:58 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
There's two cables. One from the speedo head to the VSS transducer, then another from the transducer to the transfer case.
The transducer is under the truck, on top of the transfer case crossmember. Hard to spot unless you follow the cable, it's well hidden in there.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 27th, 2011, 03:14 PM
in a 97 the speedo is electronic ... in a 94 and 95 it runs with a cable.
if you look on the frame under the drivers seat you'll find the cable, transducer and cable connecting to the transfer box. But i's definitely remove the speedo head and check that the cable spins when you drive ...
I repaired my cable with a $5 cable center from autozone ...
Old June 1st, 2011, 06:45 PM
j0nny216's Avatar
j0nny216
Jon Kleppel
1994 D90
I need to revive this thread... I understand the two seperate cables and all that (I replaced my upper cable in Feb) but what are the two wires that go into the transducer? I tried to follow them but lose them somewhere in the engine bay. I parked my truck for 4 days and it was running fine, but when I started it up after it sat there the speedo was dead (the truck is a 1994 with 150xxx miles) and now the truck wants to stall every once in a while and it is just running crappy... any ideas? Oh and the check engine light came on, and I messed with some stuff, reset the ECU drove it a little bit, it stalled but the light has not come back on (yet).
Thanks Guys
speedo
Speedometer / Odometer Not working TheBeast Defender Technical Discussions 4 June 13th, 2009 09:08 AM
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
