Speedometer issues - Defender Source
Old April 1st, 2007, 12:31 PM
Erimus 1's Avatar
Erimus 1
Neil McLeod
97 D90 NAS
Speedometer issues
I looked on the site to see if anyone has had a similar problem but to no avail.
A couple of days ago I was in my D-90 and my Speedo started to go haywire. I was unable to guage my speed as the dial stopped functioning and my mileage indicator went blank. Anyhow, got the truck home and then went out in it the next day hoping it was just a bad dream and that it was all in my head. Low and behold, the mileage indicator was still blank but at least the dial was functioning. Several trips later and it's still the case that I am able to guage my speed but the electronic mileage indicator is still not working.
So, is there a simple solution or will I have to move heaven and earth to get this corrected? I'd prefer to stay as close to stock as possible, so I don't want to put a new speedo in etc unless it is a genuine LR part(s).
That said, I could allow my arm to be twisted.
Cheerz,
Neil
Grew up with them all my life, took me this long to own one. Is it too late to be happy?
Old April 1st, 2007, 01:20 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
You really wont regret going with the VDO. They look just as clean/ sharp as the stock gauges.
Old April 1st, 2007, 04:02 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
That speedo has a semi-common problem with an internal ribbon cable connector failing, causing all sorts of issues such as the ones you describe.
I have a 94, so my situation is different, but supposedly the VDO Vision connects in using your existing sensor and is a very nice improvement over the stock piece. But it does look similar enough that it looks proper in the dash.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 1st, 2007, 04:36 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
There is also a thread on here that explains how to repair it yourself. You can search for it under "spedometer" or "odometer" and you will eventually find it. I have repaired two following these instructions. Of coarse, they are not 100% trouble free all the time. Most of the time they work as they should since I repaired them but sometimes they have episodes of blinking and random half numbers appearing. This is a common issue with 97's.
Old April 1st, 2007, 09:03 PM
Erimus 1's Avatar
Erimus 1
Neil McLeod
97 D90 NAS
I guess I'll have to go for the VDO with all the glowing praises this unit gets. I shall use D-90.com for fitting instructions.
Cheers Chaps.
Old April 2nd, 2007, 02:12 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Uh, the stock gauge on the '97's is a VDO!
So was the one on my old Porsche, that flaked out the same way(?).
Despite their reputation, my track record with VDO speedos has not been stellar.
Old April 2nd, 2007, 10:26 AM
Erimus 1's Avatar
Erimus 1
Neil McLeod
97 D90 NAS
There goes that damn spanner!
speedo
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Milage/ Speedometer calibration? oldscratchggf Defender Technical Discussions 3 January 3rd, 2006 03:59 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
» Defender Registry
97DFND
Jn101814
Bella
D110DC
Add your Defender
