Speedometer clicking - Defender Source
Old February 23rd, 2010, 10:56 AM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Anyone know what might be causing my speedometer to click at all speeds? The needle also jumps around as the speedometer makes it lovely clicking noise!!! Truck is 95ST.
Old February 23rd, 2010, 11:31 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Could the drive at the top end of the speedo cable be stripped and spinning?
Old February 23rd, 2010, 11:37 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Most likely source is like Andrew said, a bad connection between the cable and the speedo.
The less likely, and need to send it out for repair, is the magnetic bell inside the gauge is rubbing or out of alignment. Not a home repair for 99% of us. But a good speedo shop can do it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 23rd, 2010, 11:54 AM
ajh
Andrew J. Hutton
If the speedo itself is shot I'd strongly consider fitting an Autometer or VDO speedo, they use a hall-effect sender and wire vs a cable which also means no more of the "you're sort of going at about this, no that, no this" speed jumping around and no cable to wear out. (Though I do have one brand new cable I'm not going to be using if that is what you need, actually will eventually have the stock speedo too, that's the last Autometer gauge I need to get ordered.)
Old February 23rd, 2010, 12:59 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Will do some investigation this weekend. Thanks for the ideas
Old February 23rd, 2010, 02:18 PM
You may find that the cable is not fully pushed into the back of the speedo ... that causes clicking
speedo
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Clicking noise from behind IP - 97 D90 Saito Defender Technical Discussions 3 March 28th, 2006 11:17 AM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
