Speedometer calibration - Defender Source
Old August 12th, 2012, 07:22 PM
AgRover's Avatar
AgRover
Adin
1997 Defender 90 SW Badge #2493
I recently completed a engine conversion on a 1997 NAS D90 SW. I am now running a 2.8 TGV and 4.10 rear differentials with stock wheels and tires. The truck is running great, but my speedometer is off after the conversion. Is there a way to calibrate it so that it reads my speed and mileage accurately?
Old August 12th, 2012, 08:23 PM
I think there is a gear you can change out in the transfer box ...
Old August 12th, 2012, 08:39 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Easiest way to deal with this is to upgrade to a VDO speedometer. Calibrating a VDO is easy.
Old August 12th, 2012, 08:42 PM
How far off us the speedo v say your gos?
Old August 12th, 2012, 08:59 PM
is it possible to set a VDO to current mileage ... I like to see mileage continuity
Old August 12th, 2012, 09:08 PM
AgRover's Avatar
AgRover
Adin
It is up to 15 mph off at high at 70 mph. The difference is less at slower speeds.
------ Follow up post added August 12th, 2012 09:09 PM ------
Isn't the speedo on the 1997 D90 a VDO?
Old August 12th, 2012, 09:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Not to my knowledge. I gave up on my quest for milage continuity.
Old August 12th, 2012, 09:40 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I don't know. I have a 95 that had a stock mechanical counter and spinning wire cable sensor. I replaced it with a VDO speedo that counts milage electronically and that uses an electronic sensor. Calibrating that was as as easy as pushing a button. My old stock mechanical speedo was off considerably as i have 4:11 gearing and to my knowledge there is no easy way to calibrate it.
Old August 13th, 2012, 11:51 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
My 97 Speedo is VDO.
Old August 13th, 2012, 11:56 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Does it have a digital odometer?
Old August 13th, 2012, 12:00 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Stock '97s have a digital odo.
Old August 13th, 2012, 12:17 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Yes. A speedometer shop can do this for you and provide some kind of certification.
Old August 13th, 2012, 12:38 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The spedo electronic sensor at the rear of Trans box, by the brake drum for the hand brake has, four I think, different gears that you can install to get the different readings. They are color coded. I hadn't played with these too much but they do effect the speed calibration. Don't know if they will correct what you have going on however.
Land Rover 110
Old August 14th, 2012, 05:10 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
These two links were posted in another thread back in Oct.
http://www.aulro.com/afvb/technical-...ml#post1297810
http://www.land-rover-blog.co.uk/how...-a-land-rover/
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 17th, 2012, 02:10 PM
AgRover's Avatar
AgRover
Adin
I emailed the folks at ECR. They told me that Hollywood SpeedO may be able to calibrate it. I will let you know what Hollywood SpeedO says.
Old August 18th, 2012, 08:51 AM
AgRover's Avatar
AgRover
Adin
The folks at Hollywood SpeedO can calibrate it. They just need the indicated and actual speeds at 30mph, 45mph, and 60mph. It will cost $75. I'll let everyone know the results once I get it back.
speedo
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Milage/ Speedometer calibration? oldscratchggf Defender Technical Discussions 3 January 3rd, 2006 03:59 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
