Speedometer cable mod for VDO - shop? - Defender Source
Old January 20th, 2004, 01:45 PM
mgrgpg
Mark
1989 D110
Can anyone recommend a shop to make me the modified speedometer cable that I need for the VDO electronic speedo?
Mark
Old January 20th, 2004, 03:53 PM
You don't need one. You by the genuine electronic sender. It attaches to the transfer case.
See VDo Speedo Install
From above:
"Run the two wires from the '97 OEM Land Rover sender mounted in the LT-230 transfer case (if installing in a '94 or '95, mount a '97 Land Rover sender (LR #AMR 1253) and replace the stock speedometer cable with the wires from the sender)"
Old January 20th, 2004, 07:01 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
the sender unit I got has 3 wires that come out of the t-case.. any help??
Legend in My Own Mind.
Old January 21st, 2004, 09:49 AM
mgrgpg
Mark
1989 D110
John,
I posted a question about the electronic sender and a few people replied back that it does not work properly on a '94 since there is some info sent to the computer from the existing transducer and the result being the car just does not run right.
Everyone pointed to the FAQ section with the cable modification, and I felt that was the safest to do. Problem is I can not find a Speedo shop in my area.
Mark
Old December 23rd, 2013, 04:48 AM
Keebler's Avatar
Keebler
Kenneth Elliott
1994 D90 AA yellow (NAS)
the install issues on a 94.
What did you run into exactly?
I am currently in this boat.
-Ryan-
Old December 23rd, 2013, 07:14 AM
Contact the Gaugeguys.com. They can make you a cable with any ends you need.
Nisonger no longer does custom speedo cables.
Old December 23rd, 2013, 09:45 AM
It's easy to do this ... The trick is to have a resistor in line with the YBE sensor to stop it fusing. If anyone is trying to do this with a VDO send me a PM and I'll walk you through it.
Old December 23rd, 2013, 11:35 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I had spliced the line from the speed sensor on my NAS 90 but never got the speedo to work 100%. Sometimes at stop it would still be registering a certain MPH amount. So you are saying you just have to add a resistor inline for the VDO to work correctly? What size resistor?
Old December 23rd, 2013, 01:23 PM
About 110ohm should do you. Inside the YBE is a magnet on a spindle and a reed switch. The reed switch would fuse without a current limiting resistor.
My VDO takes a split second to drop to zero when I come to stop.
The same feed has to go to the ECU assuming you have a V8 nas. The ECU needs to know when the truck is moving or slowing to position the ICV idle control valve.
Sorry typo 120 ohm is what you need.
Old December 23rd, 2013, 05:08 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks - (and sorry I am hitting you with so many questions for a vehicle I don't even own anymore) - but do you wire the resister in-line on the wire that goes up to the back of the VDO speedo? My buddy is bringing the 90 to a garage tomorrow and I was going to ask them to see if they could do this for him.
Old December 23rd, 2013, 05:48 PM
It need to go between the ECU and the YBE. Doesn't matter which side. The wire up to the speedo is a 'tap' into one of the 2 wires that goes to the YBE.
Wire it ECU - resistor - YBE - ECU first. That way you'll get it right. Then attach the VDO wire.
Old December 23rd, 2013, 10:13 PM
So, like my wiring diagram? http://www.defendersource.com/forum/...8&postcount=27
Old December 23rd, 2013, 10:45 PM
Yes although I took my 12v for the VDO from in the binnacle not from down below by the YBE.
Old December 23rd, 2013, 10:56 PM
Yah. It does not really matter where to get the power. You could use the regulated output power from the speedo as well.
Old December 23rd, 2013, 11:17 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Red90 View Post
Thanks guy - I will ask the garage to add an inline resistor to that wire and see if that gets it dialed for the new owner.
Old December 27th, 2013, 08:18 AM
Keebler's Avatar
Keebler
Kenneth Elliott
I think im a going to install the GPS Sender VDO combo.
I am guessing the VSS is already wired to the correctly, minus the resistor to the CUX (pin 14 and the sw12v)
so is the YBE plug and play (as far as the computer is concerned)? also does the VSS connection fit the YBE?
2nd does anyone know where to YBE for a decent price? Rovers North is really proud of theirs..lol
-Ryan-
Old December 27th, 2013, 09:15 AM
Originally Posted by Keebler View Post
I think im a going to install the GPS Sender VDO combo. I am guessing the VSS is already wired to the correctly, minus the resistor to the CUX (pin 14 and the sw12v) so is the YBE plug and play (as far as the computer is concerned)? also does the VSS connection fit the YBE? 2nd does anyone know where to YBE for a decent price? Rovers North is really proud of theirs..lol
the VSS has the resistor inside. The YBE. Does not. Hence if you replace the VSS you have to add the resistor. I took them apart to find out!
The plug is different for the VSS vs the YBE and not long enough.
I cut the cable off the VSS and added some length and the YBE connector which is same as the brake light connector.
Try paddocks or craddock in the UK ... Non genuine is fine. It's just a spinning magnet and a reed switch.
Old December 27th, 2013, 11:36 AM
Keebler's Avatar
Keebler
Kenneth Elliott
thanks again
-Ryan-
Old December 27th, 2013, 11:48 AM
http://www.roverparts.com/Parts/YBE100540HRK.cfm
ab sells a cable kit
mod, speedo
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
Upper speedometer cable 94 NAS D90 Kilgore503 Wanted 10 February 18th, 2010 12:59 AM
Upper Speedometer Cable rmuller Wanted 0 May 1st, 2008 11:58 AM
Speedometer cable... standard threads down below? Hans Defender Technical Discussions 0 January 13th, 2007 09:33 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
