speedometer cable for 1984 110 - Defender Source
Old April 3rd, 2008, 08:47 AM
My right hand drive 110 has a 2 piece speedometer cable, and the bottom piece has broken. Does anyone know if this is a different design or length than a LHD NAS 110? Just don't want to order the wrong thing as I am in a bit of a hurry to get it fixed before my trip next week.
If anyone knows where I can get one (new or used) let me know. I already checked RDS and he's out of stock.
thanks,
charles
Old April 3rd, 2008, 08:52 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Its different.
The EFI cars used a smaller diameter speedo cable (internally) than the diesel and carb'd V8 110s. It wouldn't fit into your speedo drive gear in the transfer case.
Email:
Old April 3rd, 2008, 09:01 AM
Thanks Mike
Damn, I never thought I'd miss my speedo that much, but I really do like knowing how fast I'm going...
charles
Old April 3rd, 2008, 09:16 AM
did you try rovers north?
thanks,
charles
Old April 3rd, 2008, 09:29 AM
I haven't called yet, but still not sure what I need. For example, are the 4 cylinder ones different than a V8? Is RHD a different length than LHD?
Might just get a cheap GPS.
Old April 3rd, 2008, 10:04 AM
they should have the catalogs. gps would be cool too.
Old April 3rd, 2008, 11:09 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Did it break internally? or the whole cable?
Usually Napa and Autozone have new speedometer cores available, cut to fit and crimp on the new drive key. $10 or so for the kit IIRC.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 3rd, 2008, 11:13 AM
Just internally. I'll look into it, but it's a 2 piece design with a plastic female end on the top of the lower lower part (probably where it broke) that the bottom top part goes into. I'd probably have to change it to have the core go all the way through both pieces. Might be able to just fix where the break is if it's where the plastic meets the metal.
Worth a shot if the core is the same size as mine, thanks!
charles
Old April 3rd, 2008, 01:43 PM
the US FLAPS kits never worked on the series vehicles. dunno on the later stuff. Good luck....
charles
Old April 3rd, 2008, 01:46 PM
FLAPS?
I tracked it down to these part #s thanks to Rovers North, but they need to be special ordered (at least the bottom half which is what I need).
PRC5567 top speedo cable RN $25
PRC5664 bottom speedo cable RN $27
I think I'll see where the break is before ordering, but anything I order won't be here in time for uwharrie so I need to fix or use gps
charles
Old April 3rd, 2008, 06:11 PM
oh well, so much for trying to fix the bottom piece. My daughter just crushed the plastic head of the upper piece in the door, so it won't connect to the speedo. I'll be ordering both pieces now
Old April 3rd, 2008, 06:42 PM
Talking Flaps
FLAPS?
when they have what you need:
Friendly Local Auto Parts Store
when they don't:
F***ing Lame A** Parts Store!
Old April 3rd, 2008, 07:49 PM
Aah. Sadly around here they seem to be only good if you want bling, or to wash your car, or can lookup a standard part for a car in their computer, so I generally use the latter. For example my FLAPS only has one brand of 90W! Clearly not a big seller.
So you coming down with us to Uwharrie Dave?
charles
Old April 3rd, 2008, 08:20 PM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
charles same thing with mine. i just fixed it. gavin included the cable for mine. nice of him. i think it was a rovers north part. call les over there. good luck. you could always just use a gps.
WHO OWN THE CHIEFS? OWNZZZ OWNZZZ
my e-mail:
Old April 3rd, 2008, 09:36 PM
hijack
I'll have to work my arse off next week in order to get the time off. you guys leaving thursday? I my end up meeting y'all there later if I do go. are you camping?
charles
Old April 3rd, 2008, 09:42 PM
Work away then! Yes, leaving Thursday morning. Cm'on you know you want to. Yes camping. Taking my 8 year old and the dog.
charles
Old April 4th, 2008, 08:08 AM
Charles- try Bill @ Tntlr. When I needed a brake light switch for the 83 he was the only contender in the US that had one.
Old April 4th, 2008, 08:20 AM
I had forgotten to try him, but he doesn't have it either. No worries, I'll order from RN - no rush at this point.
Old April 4th, 2008, 09:28 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
charles
Napa is your friend.
Jimmy Buffett
110, 1984, speedo
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
