speedometer 10 MPH off one imported 1989 D110 - Defender Source
Old April 4th, 2015, 08:19 AM
davidr
David R
1997 D90 (Sold July 2014)
Hi guys,
I imported a 1989 D110 (2.5L NA diesel) and replaced the kph speedometer with a MPH one (they provided a bearmach brand). In comparison with a gps app I'm 10 MPH off of reality.
My mechanic thinks I need gear reducers. The people who sold me the truck don't have a clue.
I'm curious if any of you guys have any clue and suggested next steps?
Thanks!
David
Old April 4th, 2015, 09:12 AM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
LT230's have a small gear that drives the speedo. You can swap this out for a different toothed gear. If the speedo gear housing is not seized into the transfer case it should be a very simple swap.
Old April 4th, 2015, 11:10 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
How to replace the speedo drive gear on a Land Rover - The Land Rover Blog
You might be able to get your speedo to read correct if you have the wrong drive fitted. But +- 10MPH I would not bother with.
I just changed mine due to the cable breaking off in the drive flange. You can do it from underneath,
if it seized you might find it easier to remove the transmission brake back plate to get a set of mole grips on it.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 4th, 2015, 11:13 PM
Ben01
Ben
Defender
Tire and wheel size. 235 85 16 is what works the best I believe
Old April 4th, 2015, 11:15 PM
roverman2010
1985 LR 90 200Tdi
Yes if a blue drive is fitted
I had a red drive fitted
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old July 17th, 2015, 09:26 AM
davidr
David R
Boston Andy, I wanted to thank you for your help. Changing the small gear works. I bought both colors. In case anyone is curious it looks like they adjust the speedometer in increments of 5mph. I needed to go two gears.
David
Old July 19th, 2015, 12:17 PM
ionfender's Avatar
ionfender
IO
94 NAS D90, #1379 (SOLD)
David - where did you the gears?
------ Follow up post added July 19th, 2015 11:19 AM ------
*where did you buy the gears?
Old July 19th, 2015, 01:25 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Mine is 10mph high too...on a 19J It makes me feel a bit more endowed..lol
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
VDO 85 MPH Speedometer (P/N 437-154) chris snell Wanted 13 March 16th, 2014 08:16 PM
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
a few imported D110's for sale in NC under $10K both petrol/RHD hillstrubl The Flea Market 2 October 15th, 2010 09:39 AM
mph magazine popeohana Misc. Chit-Chat 1 March 16th, 2005 05:44 AM
vibration around 20 mph Rick Carlisle Defender Technical Discussions 19 August 25th, 2004 07:41 PM
