Speedo Transducer???? - Defender Source
Old December 18th, 2003, 09:53 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Angry Speedo Transducer????
Has anyone had any problem with their Speedo Transducer? My went last week and it was replaced. Lasted less than 6 days and back into the dealer it went. Same problem. They tell me that they have to drop and remove the t-case to see if there is a problem with something destroying it from within? This sounds like a lot of time and cash.
Checked the shop manual and it is not specifically addressed in the t-case section.
Any help would be much appreciated!
EwS
Old December 19th, 2003, 05:50 PM
are you sure it is the speedo transducer? What is it doing wrong? Check to make sure the input cable is still good, it can be replaced with the T-case in.
speedo
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
Speedo Transducer Campbell Defender Technical Discussions 2 June 10th, 2009 03:27 PM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
Speedo correction d90Monkey Defender Technical Discussions 2 April 21st, 2004 12:05 PM
