Speedo correction - Defender Source
Old April 21st, 2004, 10:10 AM
d90Monkey
James
1995 D90
Speedo correction
I have the 4.11 gears in my 95 D90 and the speedo is way off. I have been browsing some bio's and saw mention of a mod that could correct the speedo. I am a motorcycle enthusiast and know there are "yellow boxes" made for installation on bikes when you change your sprocket sizes from stock so you can see your correct speed. Am I correct in believing there is such a product for Defenders as well? If so what are they called and where can I get one.
Old April 21st, 2004, 11:40 AM
scoloco's Avatar
scoloco
'94 D90 ST
I did the speedo gear change on my jeep when I had it - it is a common thing to do. However for the defender, most people seem to go buy a VDO aftermarket speedo/odo which is adjustable.
Apparantly there is a speedo gear somewhere, but I havent gotten info on that yet.
Old April 21st, 2004, 12:05 PM
I think you can change the gear in the T-case that the short output cable going to the speed sensor is hooked to.
speedo
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
VDO speedo for sale vlocci For Sale - Parts 2 January 9th, 2004 11:32 AM
Speedo Transducer???? Eric Siepmann Defender Technical Discussions 1 December 19th, 2003 05:50 PM
» Defender Registry
Rover
mjekogian
Broken
Z.G
Add your Defender
