Speedo Cables - Defender Source
Old October 29th, 2003, 11:20 AM
scot's Avatar
scot
Scot Yount
95 Coniston Green D-90 SW
Speedo Cables
Hi all,
I have for about a year now been driving with no speedo (just haven't gotten around to fixing it) because one of the cables broke. The question is...if I get the "check engine" light and the #68 "road speed error" does that mean it is the upper or lower cable that is broken? I just want to guess right when I order the part.
scot
Wherever I go...there I am.
Old October 29th, 2003, 12:14 PM
mattwhite
Matt White
94 D-90
Same thing happened to me about a month ago. If the check engine light came on it's the lower. Although, check it before you order anything because my lower cable broke off in the transducer, and I had to order the two parts.
Old October 29th, 2003, 12:16 PM
The lower cable. The lower cable runs from the T-case to a little box above the T-case. The little box has a set of wires that runs up to the ECU, and a cable that runs to the speedo. I would pull it off and check to see that it is bad before you order a new one.
Old October 29th, 2003, 01:21 PM
scot's Avatar
scot
Scot Yount
cool you guys...thanks.
speedo
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
How does everyone route their winch cables JackW Defender Technical Discussions 10 September 12th, 2008 11:15 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
Speedo correction d90Monkey Defender Technical Discussions 2 April 21st, 2004 12:05 PM
