Speedi Sleeve on a drive flange - Defender Source
Old April 27th, 2016, 02:29 PM
For those who have installed one did you remove the flange off of the Speedi Sleeve after installing it?
Old April 27th, 2016, 03:13 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Yes. Peeled right off and no further problem!
Ryan
84 110SW County LHD
07 L322 Vogue
Old April 27th, 2016, 05:53 PM
I installed it with the flange on and made sure the seal was well seated into the housing. No more leak!!
****Disclaimer**** No leaking flange as of right now.
Onto the next leak......
Old April 27th, 2016, 08:13 PM
Pics please?
Originally Posted by pendy
I'm here for the D's
Old April 27th, 2016, 08:33 PM
Originally Posted by cgalpin View Post
Pics please?
I should have taken pictures while I did this but I didn't, sorry.
Not much to it......
Remove the four bolts holding the drive shaft in place.
Pull cotter pin, remove the big nut and remove the flange.
Yank out the seal.
Wipe out the input area of the axle.
Lube the new seal and seat it in. I used the back of a hub spanner to push it in place as I hammered the spanner.
Wipe the drive flange clean and slide on the Speedi Sleeve using the provided tool and a hammer.
Grease the new flange surface and put it all back together.
Easy peasy!!!
Old April 27th, 2016, 08:45 PM
Thanks. It was the sleeve install I was curious about. What size or model did you use?
Old April 27th, 2016, 08:56 PM
SKF99174 from Amazon
Old April 27th, 2016, 09:10 PM
I've posted pics of the speedi sleeve install somewhere on here along the way. That said,it's pretty straight forward not much really to install. Galpin let me know what questions you have specifically.
Old April 27th, 2016, 09:44 PM
Thanks Dave! Jason, I wasn't sure how they installed - didn't realize they had a lip.
Rear Output Flange Speedi-Sleeve? LR Max Series Technical Discussions 6 August 24th, 2015 05:11 PM
Drive flange bolt sirjond Defender Technical Discussions 5 November 16th, 2010 01:36 PM
110 HD Drive Flange Help Wolf Fabrication Defender Technical Discussions 34 September 13th, 2010 11:47 AM
32 spline HD Drive Flange? Jase Defender Technical Discussions 8 August 24th, 2010 07:11 AM
Drive flange bolts KevinNY Defender Technical Discussions 6 January 3rd, 2007 10:31 PM
